K&N air filter for '95 Monty SR #463716 06/13/04 07:46 PM
Two245Turbos Offline OP
Looking to get a K&N for the SR.... Can anyone suggest a retailer?
Thanks,
Ron
'95 Montero SR , 31x10.5 Yokohama Geolandar AT II,
Thule box.
Car
Re: K&N air filter for '95 Monty SR [Re: Two245Turbos] #463717 06/13/04 09:18 PM
Nice Montero there.
I have used both the cone filter and the regular drop-in filter. I found that the cone adds alot of noise and removed it since I was worried of excess dirt getting in. I put my stock box back on and its great smile nice and sealed w/ the K&N drop in but I also removed it and went w/ a paper Napa GOLD filter. I have a "drop in K&N" if you would like it PM me and you can have it just pay for shipping.
Re: K&N air filter for '95 Monty SR #463718 06/13/04 10:15 PM
Lloyd Swartz Offline
Sucks dirt, sucks water, sucks <img src="/forums/images/graemlins/butwiggle.gif" alt="" /> Do a search for extensive discussions.
Re: K&N air filter for '95 Monty SR [Re: Lloyd Swartz] #463719 06/14/04 12:52 AM
Question....If not K&N, then what would you members suggest...Tried a search, but the search on this forum really doesn't do justice <img src="/forums/images/graemlins/confused.gif" alt="" />
Ron
Thule box.
Car
Re: K&N air filter for '95 Monty SR [Re: Two245Turbos] #463720 06/14/04 12:54 AM
I would really suggest buying a NAPA Gold. It is a quality paper filter, avoid FRAM since they tend not to fit in the stock air box very well. Another good filter to consider is Purolator, Honda OEM filters are made by them.
Mitsu stock filter #463721 06/14/04 05:18 AM
matseel Offline
After using K&N, I prefer the mitsu stock,,it's actually one dollar cheaper than the Napa Gold, which I believe is a wix filter, and is good.
good hunting <img src="/forums/images/graemlins/patriot.gif" alt="" />
1994 Montero SR 3.5 DOHC, Safari Snorkel, Diehard Platinum,
OME suspension, factory rear locker, rear sway bar removed, Cobra 75 WX ST, 33" BFG KM2
New Mexico Land of Enchantment
Re: K&N air filter for '95 Monty SR [Re: Two245Turbos] #463722 06/14/04 06:54 AM
The concensous from the previous posts were that the stock filter is the way to go.
Re: K&N air filter for '95 Monty SR #463723 06/15/04 06:10 PM
I recently removed my K&N to clean and oil it and put a new stock filter in for the meantime. I really can't tell the difference yet. Maybe when I put the K&n back in. If I don't, I will just leave the stock filter in.
I have read enough posts that say K&N's increase air flow, but don't filter well. That could explain the filthy condition of my throttle body and ISC, as well as some of the idling problems that went away after I cleaned both.
My 2 cents FWIW, all learned here in these forums. <img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/wink.gif" alt="" />
Re: K&N air filter for '95 Monty SR #463724 06/16/04 04:30 AM
Went to NAPA today and picked up the Gold for the Monty.... <img src="/forums/images/graemlins/smile.gif" alt="" />
Thule box.
Car
Re: K&N air filter for '95 Monty SR [Re: Two245Turbos] #463725 06/17/04 12:43 AM
cragdweller Offline
There are those, including myself, that do not agree with the anti-K&N BS that has been posted here. I have used K&N units on many different dirt bikes and off-road vehicles, and have never seen an incident where intake dirt caused any problems with cylinder wear. If the K&N unit is oiled properly, it will filter as well as anything out there. My current truck has had the K&N filter for 145K of the 165K on it. Its been used in a variety of very dusty environments and the last compression check I did (10K ago), was excellent.
1994 3.0L 4x4 pickup.
4.62 gears (4.22 stock), 33x10.5 BFG MTs. LSD rear. Five speed trans. 172K
Previously owned Mitsubishis:
1986 2.6L 4x4 Mighty Max, 1985 2.6L 4x4 D50
1987 2.6L Raider, 1989 3.0L Raider
1995 Montero SR
PHP: 7.4.33 Page Time: 0.012s Queries: 16 (0.009s) Memory: 0.6308 MB (Peak: 0.7533 MB) Data Comp: Off Server Time: 2026-11-03 13:33:27 UTC
