4cyl tcase + adapter vs v6 tcase LENGTH
#464127
06/14/04 10:28 PM
i have both of the 4cyl tcases for my dual case setup, but dont have the ~$1000 for the adapters and drivelines. is one 4cyl tcase with the v6 transmission adapter close enough to the length of just the v6 tcase that i could run it with the stock drivelines? i need to build a crossmember and skidplate and i would rather only build it once. thanks.
Davin Nisser
'94 Pickup Xtra Cab Deluxe 3.0 V6 5spd...'84 lwb frame swap with 2" body/drive train lift and solid axle in the works...
Re: 4cyl tcase + adapter vs v6 tcase
[Re: dildinon]
#464128
06/14/04 10:39 PM
'79 sport 4x4 longbed <img src="/forums/images/graemlins/smile.gif" alt="" /> 20/22R hybrid with EB's OS valves, 268c cam, offy intake, weber 32/36, thorley header, 5 speed swap, 34" LTBs, downey 3" springs, marlin hysteer, 4.88s and locked
'91 4x4 shortbed 22R-E, W56, the dd!
Re: 4cyl tcase + adapter vs v6 tcase LENGTH
[Re: dildinon]
#464129
06/17/04 07:26 PM
if nobody knows the length difference could someone with the tranny adapter measure it?
Davin Nisser
[Re: dildinon]
#464130
06/18/04 01:31 AM
yeah, i have been wondering the same thing.....anyone going to hook us up?
"I am a shrubber, my name is Rodger the Shrubber. I arrange, design, and sell shrubberies"
[Re: Rodgertheshrubber]
#464131
06/18/04 01:44 AM
If my recall memory is right, I think Marlin told me that the V-6 adapter and gear drive T-case is 1/2" longer. I know that I did not have to have any D-shaft work done when I put mine in 6-7 years ago!!!!!! <img src="/forums/images/graemlins/butwiggle.gif" alt="" />
"Serenity through Sobriety"
[Re: OOP'S]
#464132
06/18/04 02:43 AM
did you have a 2 piece drive shaft at the time?
[Re: dildinon]
#464133
06/18/04 02:50 AM
It would be good to know for sure, since I plan on doing this mod (waaaaay down the road though)
#464134
06/18/04 03:56 AM
did you have a 2 piece drive shaft at the time? Yes I did and I think I slotted the holes for the center bearing!!! This is stuff I did along time ago so it is hard to remember exactly what I did because of all the mods I have done since!!!!!! <img src="/forums/images/graemlins/lol.gif" alt="" />
[Re: OOP'S]
#464135
06/18/04 07:29 AM
thanks oops that was the answer i was hoping for.
Davin Nisser
