Re: Another dumb tire question [Re: sweater] #464608 06/16/04 04:07 PM
hunterdan Offline OP
I know that I can get some swampers in 10.50s, but i think they would be a bit heavier than I want and would wear down way to quickly. I also want to save a bit on mileage as well. Right now Im down to 11 mpg around town. If I find that I need a more agressive tire, my buddy from work can get me swampers for about $70 a piece and I could always throw them on my old rims. Thanks for all the help again.
Dan
92 Rodeo, 3.1 TB crank, custom bumpstop spacers, DOR shackles, Flipped ball joints, D44 Rear, 4.56s and new magnaflow cat and dynomax ultraflow muffler Since been replaced by a 2 door Explorer on 31's shackles, cranked torsion bars and full exhaust
Re: Another dumb tire question [Re: hunterdan] #464609 06/16/04 06:41 PM
kobyhud Offline
I ran my 33X12.5s without a body lift. I had to do about an inch of fender trimming.
I also could have used a little bit of sledging to pound in the walls, but it didnt turn out that bad, some rubbing but not bad.
The stock rims will most likely not allow you to use 12.5s unless you stopper your steering some. You will rub on the frame without less backspacing.
You will probably also have to trim a little bit of the plastic on your front bumper if it is still the stock bumper.
There are several people who have run 33s on rodeos without body lifts. 33x10.5 the rubbing will be pretty minimal. I wouldnt worry about it. And for the drive home, oh come on! smile just dont turn as shaprly.
95 Rodeo LS, Auto, SAS, , 60 front, 14 bolt rear. 5.13 r&p, Hydro-Assist, teras..
http://www.pieceofhud.com/gallery
Re: Another dumb tire question [Re: kobyhud] #464610 06/16/04 07:01 PM
O
OffRodEO Offline
hmmm i have heard lots of time that you cannot fit 33's. i never took into concederation with dtrimming. i have ne ver seen one without a body lift and 33's. kevan
93 rodeo,3.2 manual, limo tint, nice sound system,keyless entry and a killer alarm, drop in K&N, 3 inch DOR lift, 32-11.50 BFG MT's, warn hubs zutah.com wheeler
WELLS FARGO BANK WILL RIP YOU OFF!GET OUT WHILE YOU CAN
Re: Another dumb tire question [Re: OffRodEO] #464611 06/16/04 07:15 PM
As soon as i get some cash together and get up to buying the 33's I will post pictures. It will probably be about a month or 2 before I get them. Just planning ahead.
Thanks again
Dan
Re: Another dumb tire question [Re: OffRodEO] #464612 06/17/04 03:50 AM
CPOM Offline
I guess it depends on your definition of "fit" Mine "fit but I had to cut the front fascia and they rub in the front driving around town.
CHRIS
98 Amigo, 92 Pup
Re: Another dumb tire question [Re: OffRodEO] #464613 06/18/04 03:11 AM
kobyhud Offline
hey kevan, check out the past events on zutah.com I am running 33s there without a body lift. You have seen one now smile
Its possible, at the price of about one inch of fender and about 3 inches of bumper plastic.
Re: Another dumb tire question [Re: kobyhud] #464614 06/21/04 01:03 AM
JOEDIRT Offline
Back to the 33's with or without a body lift. If you are willing to cut then they will fit with only a suspension lift. I had to cut 2" all the way around my fender and bumper. i then removed the liner and ground off the flange that sticks out in the back. It works but it is a lot of cutting. <img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" />
97 TJ SE, intake, baja wheels, 31" mudders
Stripped down to a rollin gas can.
Re: Another dumb tire question [Re: JOEDIRT] #464615 06/21/04 02:40 AM
W
Wareagle Offline
If your buddy canm get 33/10.5 swampers for $70, then forget anything else. Swampers rock and I doubt the 10.5s will rub that bad. Withour a BL, I'd forget the 12.50s altogether. Mark
PHP: 7.4.33 Page Time: 0.010s Queries: 16 (0.007s) Memory: 0.6335 MB (Peak: 0.7486 MB) Data Comp: Off Server Time: 2026-11-17 11:20:58 UTC
