what's the deal with a 95 SR? #465611 06/18/04 12:23 AM
greetings, mitsu gang! i'm not sure if this is where i should post this question, but your "Mitsu Talk" forum seems more about OT stuff, so here goes...
There's a 95 Montero SR available nearby (100K miles, $7K)
it's pretty well loaded...leather and all that stuff.
can you give me the lowdown on the these rigs? i seem to recall that you guys really love SRs. why? what about the engine (3.5, eh?)
is it gonna need a valve job at 120K miles, or was that a different engine?
i'm gonna check it out and compare it to a 96 trooper on the same lot (80K miles, $7K)
i must admit that i'm somewhat partial to the trooper, but that's only because i'm more familiar with them.
thanks,
Phil
Re: what's the deal with a 95 SR? #465612 06/18/04 12:31 AM
Lloyd Swartz Offline
thanks,
Phil
Partly its because there were more 95srs made then any other Gen II. But they also had the most powerful engine, stock body lift, can run 35s with a ring and pinon swap, stock locker, adjustable transmission, and lifetime adjustable shocks. It has a lower plenum issue(300.00 part) and will require valve SEALS, not a full valve job. Smaller, more nimble and more capable then a stock Trooper and bullet proof.
Re: what's the deal with a 95 SR? #465613 06/18/04 12:48 AM
But you don't want that one. Carlos does. <img src="/forums/images/graemlins/smile.gif" alt="" />
Re: what's the deal with a 95 SR? [Re: off-roader] #465614 06/23/04 02:31 AM
Two245Turbos Offline
Let's see...Lots of power, 3 way adjustable suspension, locking diffs,traction control,leather,large sunroof, 3rd row seating, factory 6 disc cd changer...
Ron
'95 Montero SR , 31x10.5 Yokohama Geolandar AT II,
Thule box.
Car
Re: what's the deal with a 95 SR? [Re: Two245Turbos] #465615 06/23/04 07:47 AM
traction control
I didn't realize that was available in the Montero other than the GenIII?? <img src="/forums/images/graemlins/confused.gif" alt="" />
Joel, CA
Re: what's the deal with a 95 SR? #465616 06/23/04 09:47 AM
liquidium Offline
Maybe he's talking about second gear start.
97 Montero SR: Factory rear locker, 3.5 L 24 Valve V6, ActivTrac 4wd (Love it) , 3 way suspension, four wheel disk brakes, 32x11.50 Pirelli Scorpion ATs
Re: what's the deal with a 95 SR? #465617 06/23/04 02:12 PM
traction control
Joel, CA
Started in 92. Thats what 4hh is, 4h locks the t/case. One of the finest, and earliest systems, that absolutely rocks for snow and ice highway driving. Some early models came without ABS making the system incomplete though. 92-94 I think.
Re: what's the deal with a 95 SR? [Re: liquidium] #465618 06/23/04 02:51 PM
CORRECT! Oh yea, forgot the ABS... <img src="/forums/images/graemlins/coolg.gif" alt="" />
Ron
Thule box.
Car
PHP: 7.4.33 Page Time: 0.011s Queries: 15 (0.008s) Memory: 0.6186 MB (Peak: 0.7172 MB) Data Comp: Off Server Time: 2026-11-02 07:42:04 UTC
