Temp Gauge? #465890 06/18/04 06:23 PM
G
GMJK86SR5 Offline OP
Mine does not move and I was thinking of change the sending unit. Does anyone know where the sending unit is. Has anyone had a none responsive temp guage?
Mike
Re: Temp Gauge? [Re: GMJK86SR5] #465891 06/18/04 06:26 PM
A little more info! 3.0 or 22r? What year? blah,blah, blah.....!
Re: Temp Gauge? #465892 06/18/04 06:31 PM
G
22re 86sr5
Re: Temp Gauge? [Re: GMJK86SR5] #465893 06/18/04 06:49 PM
ok, Maybe this will help you out! http://www1.autozone.com/servlet/Ui...OCATIONS%7C%7ECOOLANT+TEMPERATURE+SENSOR
Good Luck! <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: Temp Gauge? [Re: GMJK86SR5] #465894 06/18/04 08:04 PM
Pappy Offline
Intake manifold, against head, between number 2 and 3 cylinders. Single wire connector, might be blue.
Re: Temp Gauge? [Re: GMJK86SR5] #465895 06/18/04 09:29 PM
DRTDEVL Offline
It's not the sending unit/temp sensor... It is a bad ground on the driver's side of the dash. Several people here have had the same problem, and I have the "dead guage syndrome" in my '87. Every now and then, it will read cold in the morning, and occasionally (like once per month) it will warm up normally. But usually when it reads cold in the morning, it jumps halfway up after about 30-45 seconds.
Search around on here... There is a post about it with detailed info and pics of how to fix it. <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: Temp Gauge? [Re: DRTDEVL] #465896 06/18/04 09:34 PM
Re: Temp Gauge? #465897 06/18/04 09:46 PM
DRTDEVL Offline
Nah... That ain't it.
This is it! <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: Temp Gauge? [Re: DRTDEVL] #465898 06/19/04 01:01 AM
ahh your right, sorry for the confusion! <img src="/forums/images/graemlins/frown.gif" alt="" />
PHP: 7.4.33 Page Time: 0.010s Queries: 15 (0.007s) Memory: 0.6214 MB (Peak: 0.7076 MB) Data Comp: Off Server Time: 2026-11-03 04:51:55 UTC
