taking off the doors #465947 06/18/04 09:50 PM
i wanted to know if any one can give me instructions on how to take the doors off of my 1990 trooper. is it really as easy as it looks? its been my experience that nothing is ever that easy so sorry if this sounds dumb to you guys. its a 4 door with no power windows or locks. i also wanted to know if anyone has tube doors for their early troopers. pics would be cool. TIA
Re: taking off the doors #465948 06/19/04 02:21 AM
StinkBug Offline
Should be 4 bolts and a little pin on each door. takes about 5-10 min per side.
Dallas
[color:"blue"]Crew Chief, RedBull RockCrawling Team [/color]
[color:"red"]StinkyFab Custom Metal Creations[/color]
Project StinkBug
Re: taking off the doors [Re: StinkBug] #465949 06/19/04 02:56 AM
what should i do for mirrors? what have other people done? and yet again what about tube doors? pics would be nice.
Re: taking off the doors #465950 06/19/04 11:07 PM
CPOM Offline
I don't think any manufacturer has made tube doors for Isuzus. Mirrors would have to be mounted to the cab, or you could use magnet ones.
CHRIS
98 Amigo, 92 Pup
Re: taking off the doors [Re: CPOM] #465951 06/20/04 12:19 AM
hunterdan Offline
If you want some tube doors, you should be able to go to the junkyard and get the hinges off a similar vehicle. Then draw or have someone draw up some plans for the doors. You will probably need the door latch too. It will probably be easiest to make them out of square tubing. Then once you get a design, take it to a machine shop, buy the materials you need and have them fab it up. Im pretty sure machining and welding costs will be less than $100 and the steel will probably cost another $100. I might be able to draw up some plans for a set. But they will be for a 92 Rodeo since that is the only thing I can get the proper measurements for. If you get a good design you can probably sell it or partner up with a machine shop to build them and split the profits.
Dan
92 Rodeo, 3.1 TB crank, custom bumpstop spacers, DOR shackles, Flipped ball joints, D44 Rear, 4.56s and new magnaflow cat and dynomax ultraflow muffler Since been replaced by a 2 door Explorer on 31's shackles, cranked torsion bars and full exhaust
Re: taking off the doors [Re: hunterdan] #465952 06/20/04 11:41 PM
Chris Perosi Offline
Isuzu Staffer Emeritus
Ya might consider the junkyard route, 'cept take it one step further. Look for a set of doors that have hinges, handles, mirrors, and latches in good working condition, but are otherwise all screwed up - rusted out, dented, broken glass, etc. Pull 'em off and make the junkyard man an offer -- if they were in good condition they'd easily sell, but in this shape, you're the only one who'd want them, so you should get them cheap if the junkyard guy isn't a complete idiot. Makes more sense to get 10 bucks from you for the doors than to let them sit in the junkyard for an eternity, because most "sane" people buying junkyard doors are getting them to REPLACE doors that are in exactly the condition you're trying to PURCHASE.
Anyway, once you have the doors, you can try to keep the mechanicals in tact while removing/replacing/refurbishing the sheet metal and cutting them to your liking. I've always envisioned something similar to the Jeep half doors with the front end cut just above the upper hinge and the rear end down lower. Then remove the skin in the center area of the door 'cept where the handle is, add a little "door edge trim" for your local auto parts store, and effectively you have "factory" half doors for cheap, that is, if the junkyard man is willing to wheel and deal on something he most likely couldn't otherwise sell....
My 2 cents,
Chris
Re: taking off the doors [Re: Chris Perosi] #465953 06/21/04 12:49 AM
JOEDIRT Offline
Well If you want tube doors you can call stinkbug, and see if he will make you a set. He did for me last year and they are great. To take the doors off you have to take out 4 bolts per side cut speaker wires and I used my climbing gear to suspend them from a tree to get them off. They are heavier thanthey look when you are trying to work on them and hold them at the same time. I mounted mirrors from oriellys on the frame of the tube doors. Now all I need is a rear set. <img src="/forums/images/graemlins/kewl.gif" alt="" />
97 TJ SE, intake, baja wheels, 31" mudders
Stripped down to a rollin gas can.
Re: taking off the doors [Re: JOEDIRT] #465954 06/21/04 02:25 AM
Just take a good look around before you go cutting any wires -- I've taken doors off a 90 Trooper, a 90 Amigo, a 98 Amigo, and kinda stood by the wayside while Gilbert took his off his 94(?) Trooper... Never had to cut any wires. Even the 98 Amigo with power everything had a handy-dandy little plastic clip under the rubber grommet where the wires go from the door to the body -- on the body side IIRC. Just lift the grommet, unplug, and off ya go...
And AMEN about what a PITA it is to put 'em back on when you have to line everything up correctly AND hold a much-heavier-than-it-looks door... Pays to have two other people holding the door while you do the "hard" work of lining it up. <img src="/forums/images/graemlins/wink.gif" alt="" />
-Chris
Re: taking off the doors [Re: Chris Perosi] #465955 06/21/04 03:02 AM
yah i looked and i didnt see any wires so i dont think taht i am going to have any problems with that.
Re: taking off the doors #465956 06/22/04 01:42 AM
TROOPOWER Offline
andy
when i get back into town this wednsday i will show you the easy way to get the doors off and run a mirror/tub.
i can also make the doors for you if your willing to help. they might not be pretty but we can knock something out.
anyways, we can do it at toms shop...wont take long at all.
send me an email whenever you want
Joe Mancin
85 Toy ex-cab 33s
PHP: 7.4.33 Page Time: 0.016s Queries: 15 (0.012s) Memory: 0.6316 MB (Peak: 0.7364 MB) Data Comp: Off Server Time: 2026-11-18 03:40:41 UTC
