Backspacing question #466403 06/20/04 02:50 AM
NJ_dup1 Offline OP
Ok, first is it just me or does the search feature bring up a LOT of stuff that isnt related to the phrase searched?
Anywho
I have a chance to buy 15x8 wheels for my 93 rodeo, the back spacing is 3.75" I THOUGHT my stockers were 3.25?
1) Is that the correct # for the stocker backspacing
and
2) Are these wheels gonna fit if I purchase them? Or should I skip on them?
Sorry, i know its a dumb question, just dont want to end up with something that wont work out for me
Nate Johnson
1993 Isuzu Rodeo 4wd - Not Much Crap
1998 Chevy Silverado 2500 - A little More Crap
2006 Suzuki Z400 - A Bit More Than A Little More Crap
2004 Yamaha Raptor 660 - Lots of Crap
Re: Backspacing question [Re: NJ_dup1] #466404 06/20/04 04:20 AM
CPOM Offline
To measure your backspacing just get 2 rulers. One to measure the depth, the other to act as a reference point. (so you can make a perpendicular angle)
I run 3.75" backspacing on my truck with 12.5" tires and they stick out in the back 1-2". The front is even for some reason (maybe due to the fact its lifted high)
CHRIS
98 Amigo, 92 Pup
Re: Backspacing question [Re: NJ_dup1] #466405 06/20/04 08:56 PM
randii Offline
Tell us more about what phrases you are searching and the exact context. You'll get different sets of results with "bugger mump marmot tires" and bugger "mump marmot" tires (grouping with quotes), bugger mump +marmot tires (requires 'marmot'), and bugger mump marmot tires (no grouping, no order, returns each post with ANY of these words).
Also, some subjects like tires have been hashed so many times that it is really hard to get good search results even with well-chosen search criteria. Tell us more about what you'd like to find out and maybe someone can suggest better search criteria for you or provide direct links from their own searches...
Anywho
FWIW, on your original question, your 93 Rodeo is pretty flexible for backspacing... that's a small variance you mention, so if the wheels are the right price, IMHO, that's close enough for size. Buy 'em!
Randii
Randy Burleson
4x4Wire Managing Editor Emeritus
Mongrel Isuzu Amigo
Re: Backspacing question [Re: randii] #466406 06/21/04 12:55 AM
JOEDIRT Offline
I am running 31-10.5 on my 96 rodeo. I have the back lifted up 1.5 inches and the front is stock. I did chop 2" off the front fender and bumper all the way around and reworked the interior of the fender. The wheels are 15x8 with 3.75 backspacing and the correct bolt pattern. in other word they will fit. You might have to do a little trimming. <img src="/forums/images/graemlins/kewl.gif" alt="" />
97 TJ SE, intake, baja wheels, 31" mudders
Stripped down to a rollin gas can.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6029 MB (Peak: 0.6600 MB) Data Comp: Off Server Time: 2026-07-09 17:10:14 UTC
