Lubrication question (grease fittings) #467099 06/21/04 08:42 PM
Dbryan22 Offline OP
In my repair manual, it points out eight places for lubrication of the Spider grease fittings. In the manual that came with the truck (not the repair manual) it says use Lithium base chassis grease, NGLI No. 2 for the Spiders.
But I can not find any other grease fittings. Some of the above eight look like thay are part of the slide yoke & double cardan which use a different grease. And on top of that, what about by the wheels, any suspension grease fittings? Thanks one and all.
2001 SR5 4Runner 4x4
Re: Lubrication question (grease fittings) [Re: Dbryan22] #467100 06/21/04 10:48 PM
aowRS Offline
I'm under my '01 every 5,000 miles or so to grease all of the fittings. From memory, I grease either 8 or 10 fittings. After posting on here three years ago, I opted to use a good quality chassis grease for all of the fittings. While there may be merit to using different types for the different joints, I'd wager that most 4Runner owners never touch these - ever. That's usually followed by a post regarding some driveline component failure...
When I do mine, I have the truck on a level surface, and in neutral. Then I get under there and do the rear fittings first. If you can't reach them, grab the driveshaft and slowly rotate it. The truck will move slowly, and you'll get at the fittings. As long as the truck is not in 4WD, you can spin the front shaft at will and hit those fittings with ease. There are no other fittings.
I also keep wheel chocks a few feet from the front and rear of the vehicle - just in case. If you don't have a flexible grease gun extension - get one. It truly helps.
Andreas
2001 4Runner SR5 4WD, Dorado Gold, 303,000+ miles
2014 Audi A4, Monsoon Gray
1995 Porsche 993, Polar Silver
Re: Lubrication question (grease fittings) [Re: aowRS] #467101 06/22/04 03:19 PM
Does anyone know where there is a good write-up with pictures for all our lubrication points on 3rd Gen 4runners? I checked out YotaTech also and there is nothing there. It would be great for someone to do this for us newbies who want to learn how to do this... <img src="/forums/images/graemlins/baby.gif" alt="" />
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5911 MB (Peak: 0.6470 MB) Data Comp: Off Server Time: 2026-06-21 12:08:32 UTC
