"Toc-toc-toc-toc" as opposed to "tic-tic-tic-tic"... #468228 06/24/04 04:41 PM
glock Offline OP
...and NOT a "Knock-knock-knock"!!
Said sound is eminating from the passenger side, and appears to be heat related in that it quiets down at idle after a few minutes in park. Does my 3.5's cylinder head have rocker arms and can they be adjusted? Can that be what this is? <img src="/forums/images/graemlins/confused.gif" alt="" />
Your $.02 very much appreciated. Vacation and a long ride hauling a popup camper looms in two weeks! <img src="/forums/images/graemlins/smile.gif" alt="" />
2012 Jeep Liberty
2000 Trooper 3.5, LS/Burgandy & Grey(O.B.T.2)...<img src="/forums/images/graemlins/cheers.gif" alt="" />
I WAS down with O.B.T. '88 Trooper II
("Old Blue Trooper!" said my kids!...)
Re: "Toc-toc-toc-toc" as opposed to "tic-tic-tic-tic"... [Re: glock] #468229 06/25/04 12:14 AM
bob large Offline
The old toc, toc, toc... Ya that most likely a belt tensioner. At least thatÆs what it was in my case. I was thinking major engine problems cuz it started so suddenly. But no, just the belt tensioner. <img src="/forums/images/graemlins/patriot.gif" alt="" />
Steve C
Re: "Toc-toc-toc-toc" as opposed to "tic-tic-tic-tic"... [Re: bob large] #468230 06/25/04 12:27 AM
glock Offline OP
Did it display the same heat related symptoms??
"Toc-toc-toc" when hot...then quiet within minutes at idle?
2012 Jeep Liberty
Re: "Toc-toc-toc-toc" as opposed to "tic-tic-tic-tic"... [Re: glock] #468231 06/25/04 06:51 PM
glock Offline OP
70 views and counting...Don't be afraid- any input will help here! <img src="/forums/images/graemlins/notooth.gif" alt="" />
2012 Jeep Liberty
Re: "Toc-toc-toc-toc" as opposed to "tic-tic-tic-tic"... [Re: glock] #468232 06/25/04 06:56 PM
bob large Offline
Ya, mine was really loud at start up then within about 5 or 6 minutes it was barely noticeable.
How long has it been since you have replaced belts and tensioner? If the belts look alittle cracked you might as well do it, and see if that fixes the sound. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Steve C
Re: "Toc-toc-toc-toc" as opposed to "tic-tic-tic-tic"... [Re: bob large] #468233 06/26/04 02:40 PM
I've seen a lot lately about replacing the tensioner. Could some explain why? If I'm thinking of the same part, it is a hard metal piece that attaches to a spring and has a bolt that allows for tightening/loosening right? What gets warn out on these to cause the symptoms above?
Since doing my engine I have a noise similar but more like a tick that also is prominent at start-up to warmed-up and then disappears.
Re: "Toc-toc-toc-toc" as opposed to "tic-tic-tic-tic"... #468234 06/26/04 06:50 PM
glock Offline OP
Interesting in that my symptoms are magnified by higher engine temps, and definitely minimized after a couple minutes running at idle...eventually to the point of disappearing completly...
Sorry...I tend to repeat myself when under stress...
...repeat myself whe- damn!
2012 Jeep Liberty
Re: "Toc-toc-toc-toc" as opposed to "tic-tic-tic-tic"... [Re: glock] #468235 07/01/04 03:33 PM
glock Offline OP
OK...Last call- AND I MEAN THAT!
I haven't had the time to get to Isuzu, my "personal" mechanic has been ill, I have to tow my newly bought pop-up ( <img src="/forums/images/graemlins/smile.gif" alt="" /> )and I am treading water here on this issue... <img src="/forums/images/graemlins/baby.gif" alt="" />
Any more insight would be greatly appreciated.
Thanks in advance- you guys are the best. <img src="/forums/images/graemlins/kewl.gif" alt="" />
2012 Jeep Liberty
PHP: 7.4.33 Page Time: 0.016s Queries: 15 (0.012s) Memory: 0.6246 MB (Peak: 0.7192 MB) Data Comp: Off Server Time: 2026-11-18 11:51:27 UTC
