wandering cj7 #468517 06/25/04 02:44 PM
doc long Offline OP
tell me if i'm on the right track here.
i picked up an 85 cj7 and it has a decent wander or oversteer that i didn't have with the 83 (before it hit the tree). took it to get aligned and they said the ball joints were good. i noticed as i was piecing my surviving 83 parts on to the 85 that the front hubs wouldn't unlock. there is no front drive shaft in it right now but the diff turns with the tires. could this contribute to the wandering? could it be the front axle ujoints? the guy at the shop loosened the steering box so it helps with the wander/oversteer but i still feel it and it wasn't there with the 83 axle. if it is the ujoints, how hard of a job is that and do i have to take the balljoints out anyways to get at them?
thanks to anyone who actually read all that
Brian <img src="/forums/images/graemlins/smile.gif" alt="" />
Re: wandering cj7 [Re: doc long] #468518 06/26/04 12:38 AM
JeePete Offline
I believe bad U joints could contribute. You don't have to mess with the ball joints.Take the wheel and brake rotor off and you will see 8 (I think) 9/16 nuts. Take them off and the spindle might come off. I say might cause it might be rusted in place. when you get it out the axel will come right out assuming it's a stock D30. Changing the u joints is at least twice as hard as on a driveshaft cause all four bearing caps have to be pressed out. (Personally, I cut the old u joints out with a torch which makes the job a lot easier. Just got to be ready for when the O2 hits the grease! Instant flame thrower! <img src="/forums/images/graemlins/notooth.gif" alt="" /> Don't try this at home <img src="/forums/images/graemlins/shiner.gif" alt="" />) Oh yeah, be extra carful putting the axels back in. The tubes tend to be full of dirt.If you just shove them in its a good way to ruin your seals and cram some sand into the diff. I made a special tool to excavate the tubes before reassembly. You got to hold the end of the axel up so it doesn'tscrape the bottom of the tube.
Re: wandering cj7 [Re: JeePete] #468519 06/26/04 06:16 AM
If the front axle is constantly draging, it can cause a littlle oversteer. i would repair the hubs before assuming the u-joints are bad. usually a bad ujoint is very abvious on turns and is easy to visually inspect.
Re: wandering cj7 #468520 06/26/04 08:59 AM
JeePete Offline
Fixing the hubs goes without saying, but, if I got a new 19 year old Jeep, and had a problem in the front end, I would pull the whole thing apart (except ball joints) and check everything out. Wheel bearings, spindle bearing, and U joints. I would also pull the diff cover and check conditions in there. When I got my 86 the tranny and both diffs were full of water. I also had bad spindle bearings and one bad wheel bearing, one obviously bad u joint (if one's bad change 'em both) and one bad u joint that was not obvious at all till I pulled the axel. (don't forget to change all fluids, check all u joints, brakes, axel bearings, tie rod ends and such, you know, routine new CJ stuff.) <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: wandering cj7 [Re: JeePete] #468521 06/26/04 01:43 PM
doc long Offline OP
thanks guys, i'm gonna start with the hubs and probably wheel bearings and look at the ujoints while i'm under there. i have a hunch that things might improve if i get the hubs to unlock first. i also have another 82 axle with the same gearing that i might just rebuild and then swap in.
thanks again,
PHP: 7.4.33 Page Time: 0.011s Queries: 15 (0.007s) Memory: 0.6060 MB (Peak: 0.6678 MB) Data Comp: Off Server Time: 2026-11-16 08:40:56 UTC
