ubolt flip question #468846 06/26/04 04:43 AM
W
whitetoy Offline OP
This is for the rear of an '84 runner.
I know that most guys use Chevy ubolt plates or fab their own.
Has anyone used the ubolt plates from a 2wd
toyota pickup for the flip ? Wouldn't this work ?
Rick
1984 4Runner
Re: ubolt flip question [Re: whitetoy] #468847 06/29/04 02:12 PM
foxtrapper Offline
Not exactly following you.
I did look at using the rear axle assembly out of my 2wd truck in my 4x4 (both 1986 models). I didn't do it because of the work involved. It wasn't much, but just wasn't worth doing for me. The problem wasn't in bolting the axle onto the spring, it was the rest of the stuff. Frame mounted bump stop, different e-brake design, etc. The match up to the spring itself is just fine though.
Re: ubolt flip question [Re: foxtrapper] #468848 06/29/04 03:07 PM
I'm not sure if the 2wd spring plates would work or not. I used Ford Ranger plates that I drilled out for my 9/16" ubolts. Seems to have worked nice.
For the front I just made new plates from 3/8" plate.
Re: ubolt flip question #468849 06/29/04 04:59 PM
Elbow_Greese Offline
The 2wd brackets will bolt on, it just depends on your type of shocks that will determine how much needs to get changed.
The 2wd brackets use the same shock mounts as the 83 trucks, but I think in 84 they changed to a larger shock mount.
Other than that, I don't think there's much different.
The 2wd plates are already setup to clamp the spring to the axle.
Todd
1986 Pickup extracab longbed "Woody edition"
SAS - 33's, 5.29's, lockright rear.
02 IS300 SportCross - my "DD"
94 2wd v6 extracab
04 Outback Wagon- wife's/family car
Re: ubolt flip question [Re: Elbow_Greese] #468850 06/30/04 03:55 AM
ToyinAround Offline
2WD huh, thats a good tip. I've been meaning to do this myself for awhile now and i know where there's a couple at the local boneyard i'll have to look at. <img src="/forums/images/graemlins/kewl.gif" alt="" />
1987 4Runner SR5,SAS,6 inches of lift,35in BFG's,Welded Front,Detroit E-Z locker V-6 Rear, 5.29's
Re: ubolt flip question [Re: ToyinAround] #468851 06/30/04 07:42 AM
hey, shoot in a picture or two if you end up doing this, sounds interesting.
Re: ubolt flip question #468852 06/30/04 08:11 PM
ToyinAround Offline
Sure, no problem <img src="/forums/images/graemlins/kewl.gif" alt="" />
PHP: 7.4.33 Page Time: 0.011s Queries: 15 (0.008s) Memory: 0.6118 MB (Peak: 0.6895 MB) Data Comp: Off Server Time: 2026-11-02 05:16:56 UTC
