Its not that diffacult... is it? #469003 06/27/04 01:32 AM
j03 Offline OP
Basicly I need to do this http://www.4x4wire.com/forums/showf...mp;amp;sb=5&o=14&fpart=1
But it seems to be an impossible one man job. No matter what I do I cant pull/push the axle shaft far enough to get the clips on and if I let go the tention from the boots just pulls the axle shaft back in. Its driving me nuts..
Should it be this friggen hard?
90 Trooper 2.6 - AMC head
Re: Its not that diffacult... is it? [Re: j03] #469004 06/27/04 01:16 PM
Bigpoppax2 Offline
The end of the cv joint (axle) should be threaded. You can thread a bolt in there and pull and get the snap ring on there. It can be a bit cumbersome but not too bad. I did the ones on my trooper myself.
Re: Its not that diffacult... is it? [Re: Bigpoppax2] #469005 06/27/04 03:35 PM
j03 Offline OP
Ah ha... Thank you. I knew there had to be something.
Re: Its not that diffacult... is it? [Re: j03] #469006 06/27/04 09:17 PM
are you using actual snap ring pliers? <img src="/forums/images/graemlins/kewl.gif" alt="" /> (they WORK!)
PHP: 7.4.33 Page Time: 0.011s Queries: 15 (0.008s) Memory: 0.5983 MB (Peak: 0.6581 MB) Data Comp: Off Server Time: 2026-11-18 11:55:28 UTC
