low lift springs? #469845 06/29/04 12:34 AM
kyle-22r Offline OP
my front springs are pretty much shot(negatively arched) and i'm looking to replace them. anybody know of any decent springs with around 1.5-2" of lift for the front of a straight axle pickup? i'm looking for something that'll work with my stock steering(or at least not having to go all the way to crossover just yet), but i'm having a really hard time finding any front springs with less than 3" of lift
any good homeade options either?
'91 4x4 shortbed
22R-E, W56, the dd!
Re: low lift springs? [Re: kyle-22r] #469846 06/29/04 01:09 AM
superv43 Offline
OME (Old Man Emu) offers a set of leaf springs with about 2" of lift.
I have a set of these on my 85 pickup. They flex pretty well and the overall ride is much improved. They also are completely bolt on and will work well with the stock push-pull steering and torque rod. On the downside, they are not cheap at around $170 each spring.
Here is a link to a review of these springs
OME Review
Greg
Re: low lift springs? [Re: kyle-22r] #469847 06/29/04 01:13 AM
Brian894X4 Offline
If you can afford them, ARB's OME 2" lift springs are probably the best aftermarket (non-custom) springs on the market. I would go with either them or have Alcan make you a custom set to your specifications. Alcan has some of the best customer service and friendliest attitude of any 4x4 parts company I've worked with. Both options are going to be around $400+...but well worth it.
Re: low lift springs? [Re: Brian894X4] #469848 06/29/04 02:03 AM
kyle-22r Offline OP
the OME setup is very tempting. i just wish there was more info on the net about them, i don't like the idea of having to call just for spring specs.
i wonder why NWOR seems to be the only place selling 2" springs besides OME <img src="/forums/images/graemlins/barf.gif" alt="" />
'91 4x4 shortbed
22R-E, W56, the dd!
Re: low lift springs? [Re: kyle-22r] #469849 06/29/04 03:53 AM
mainer Offline
you could go with the downey 3" springs i hear they are pretty soft and quickly sag to 2" or so
00 tacoma 4x4 ex-cab stock 193,000 and counting
85 long bed pickup 4x4 frame off restoration. rear lock rite 31's 268,000 miles
51 cj3a stock everything orginal 2500 original miles
Re: low lift springs? [Re: kyle-22r] #469850 06/29/04 02:12 PM
A
aedavis Offline
I've run OME springs since 1997 on my 85 4Runner and they are great. They are not super soft and flexy but they do articulate well and I have zero sag in 7 years of rock crawling.
They are well worth the money.
Allan
Re: low lift springs? [Re: aedavis] #469851 06/29/04 02:51 PM
A
averkam Offline
A local spring shop may be able to build you some springs for less money that will work every bit as good as origional equipment. However, I would say that you will get what you pay for. The OME springs etc will be better.
2000 Ext Cab SR5 4WD 2.7L 5-speed.
Re: low lift springs? [Re: averkam] #469852 06/29/04 04:12 PM
use stock from Jeep YJ springs (less than $50 or even free if you know some jeepers) and have custom u-bolts made for about $35.
I have RE 1" lift YJ springs in my 4Runner and they're about +2.5 over stock. add-a-leaf's for YJ's are rediculously cheap if you want more lift. like $50/pr new.
PHP: 7.4.33 Page Time: 0.014s Queries: 15 (0.010s) Memory: 0.6214 MB (Peak: 0.7199 MB) Data Comp: Off Server Time: 2026-11-01 17:30:44 UTC
