special tools for 3.5l timing belt? #471165 07/01/04 05:43 PM
davemtb Offline OP
Going to tackle the timing belt this weekend. I've already read tons of posts regarding the subject and still have some questions like..
What is a bulldog clip?
What is the special tool I will need to remove the crank pulley?
Will a strap wrench work in it's place?
Will I need a gear puller?
Any other tips or tricks? I plan to use a breaker bar and my starter to remove the crank bolt.
Thanks,
Dave in KC
Dave Smith
'96 SR - 31x10.5 Tires
"Facts are meaningless. You could use facts to prove anything that's even remotely true!" Homer Simpson
Re: special tools for 3.5l timing belt? [Re: davemtb] #471166 07/01/04 06:27 PM
Alex Kogan Offline
You will need a special tool like this to remove crank pulley (I build that one for DougB recently, haven't heard any complaints or praises yet <img src="/forums/images/graemlins/rolleyes.gif" alt="" />):
Strap wrench didn't work for me. I build tool similar to above for myself awhile ago but it is long gone. You can read about my tool and belt replacement here(I did it on 3.0L though): http://monterorider.tripod.com/offroad/Tool/Tool.html
Another fellow in KC, awesome. Should go wheeling together some day.
08 PowerWagon (stock!)
Re: special tools for 3.5l timing belt? [Re: Alex Kogan] #471167 07/01/04 06:34 PM
Alex Kogan Offline
Oh, If you will turn starter, won't you be tightening that bolt <img src="/forums/images/graemlins/shocked.gif" alt="" /> you might get some interesting results then.
Or may be not. Engine turns counterclockwise! Doesn't it? <img src="/forums/images/graemlins/confused.gif" alt="" /> I believe the bold has standard thread. Well then it might work. Actually no, it won't <img src="/forums/images/graemlins/confused.gif" alt="" />
Ah whatever.
Re: special tools for 3.5l timing belt? [Re: Alex Kogan] #471168 07/01/04 07:37 PM
davemtb Offline OP
Nothing like a little local support. <img src="/forums/images/graemlins/cheers.gif" alt="" />
On edit, I looked at the tool you made and it looks very doable, thanks!
Where do you buy your OEM parts??
Dave Smith
Re: special tools for 3.5l timing belt? [Re: davemtb] #471169 07/02/04 04:23 AM
A bulldog clip is a metal spring clip that is most often used for holding sheets of paper together. The small ones are useful when replacing the timing belt as they can be used to hold the belt in place, on the cam sprockets, as you weave the it around the rest of the pulleys/tensioner. Office suppliers will have these in stock.
Cheers <img src="/forums/images/graemlins/smile.gif" alt="" />
Re: special tools for 3.5l timing belt? #471170 07/02/04 02:54 PM
davemtb Offline OP
I've got a box of binding clips in my desk. Cool, thanks.
Dave in KC
Dave Smith
Re: special tools for 3.5l timing belt? [Re: davemtb] #471171 07/02/04 03:58 PM
Alex Kogan Offline
No prob.
I had a good luck with Conicelli part. In emergency I used Northtown Mitsubishi on Vivion Rd. They charge list prices but were able to overnight some small stuff for me for just $3 extra. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: special tools for 3.5l timing belt? [Re: davemtb] #471172 07/07/04 09:11 AM
Mike_Glenn Offline
If you didn't complete the job yet, here is a trick I used to avoid pulling the crankshaft pulley.
the only reason to remove the crankshaft pulley is so you can remove the lower timing belt cover. I removed it the cover different way, by cutting it in 2 places with my dremel, then it came right off. To re-install it, I used some RTV to 'glue' it back together.
Saves lots of time if the crankshaft pulley wont come off easily!
'94 Montero 3.5 SR, 202,000 mi.
Re: special tools for 3.5l timing belt? [Re: Mike_Glenn] #471173 07/07/04 02:44 PM
davemtb Offline OP
Did the job over the 4th weekend. The crankshaft pulley didn't give me any trouble. I built the tool referenced earlier in the thread on Alex's site. I snapped 1/4" bolts and went to 3/8". The torque spec was 150 ftlbs <img src="/forums/images/graemlins/shocked.gif" alt="" /> I also broke a lower cover bolt upon removal, so your tip would have saved me that time plus the fab time on the tool. A couple of hours at least.
Here's some additional thoughts to finish the thread. The job was pretty straight forward, but this was my first time replacing a timing belt. There was some trial and error. My knuckles left a trail of blood around the engine compartment <img src="/forums/images/graemlins/rolleyes.gif" alt="" />. Those cams were meatgrinders for sure. Once I figured out how to use wood shims and vice grips to lock the cams to each other and the belt in place, everything went good. To tension the timing belt, I used an awl in one of the pinholes, a deepwell socket on the center bolt, and a small prybar in between to tension the belt. I was pleased with how accessible all of the bolts were. I could see everything I needed to remove. The DOHC has an accessory mounting plate on the front that made the job quicker than removing a bunch of individual mounts and brackets. The ratcheting flat box wrenches were my main tool in the tight areas and worked great. I will be able to do it faster next time, but can't even comprehend how someone could do this job in 4 hours. Add replacing the water pump to the list of chores, and the job took me close to 15 hours <img src="/forums/images/graemlins/drunk.gif" alt="" /> Of course this was 3-4 hours on messing with the belt and the timing marks themselves, but also included numerous stops to blow up fireworks for my kids <img src="/forums/images/graemlins/smile.gif" alt="" />
Thanks to everyone for the help from this forum.
Dave in KC
Dave Smith
PHP: 7.4.33 Page Time: 0.028s Queries: 15 (0.024s) Memory: 0.6328 MB (Peak: 0.7374 MB) Data Comp: Off Server Time: 2026-11-20 00:44:45 UTC
