Loud pulleys #472081 07/03/04 12:51 PM
JeepJon Offline OP
Ok.. I did a bit of deep water this last weekend. never got stuck in any of it, just had to push through it. Now the engine is louder, I have some kind of whining coming for the front of the engine. I think it is a pulley. I have A/C
and that pulley went out once before but i have replaced it and I am pretty sure that it is not that one. Does any one know if you can grease pulleys? maybe with some WD-40? or some other lube to keep things quiet in there?
Jeep 2000 TJ Black Sahara, Safari Snorkel, 2" Budget Boost, New Long reach shocks, BFG Mud Terrains 265/75R16,KC Daylighters mounted on the windshield brackets www.mosquitocounty4x4.com
Re: Loud pulleys [Re: JeepJon] #472082 07/03/04 05:44 PM
the WD-40 won't keep them quiet in the long run, but it will shut them up tempararyly so you can figure out which one is making noise.
Re: Loud pulleys #472083 07/03/04 07:08 PM
find the pulley thats making the noise then go to checkers and they have them there i dont recommend getting it at a junck yard cuz i have gone through 4 idler pulleys to find out they suckand last no more than a month. im almost sure that its going to be an idler pulley cuz that same thing happend to my 4.0l. that i know of checkers is the only one that carries them aside of the delership.
Re: Loud pulleys #472084 07/03/04 11:52 PM
JeepJon Offline OP
Checkers..ok I will check..do you have a website or link for them. I found a few with that in the name.
Re: Loud pulleys [Re: JeepJon] #472085 07/04/04 09:44 AM
valleycat Offline
checker, schucks, and kragen are the same. just different names in different parts of the country.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.5995 MB (Peak: 0.6622 MB) Data Comp: Off Server Time: 2026-06-17 04:17:43 UTC
