HOW the Hell do I get the INNER BEARING SEAL OUT?
#472506
07/04/04 09:54 PM
ive been trying to get this thing out for the past 30 min and no luck. im using a screwdriver, any tips?
Re: HOW the Hell do I get the INNER BEARING SEAL OUT?
[Re: 87Toy4x4]
#472507
07/04/04 10:31 PM
Ummmm...yea....what seal are you talking about?
If you are talking about a wheel bearing seal or an axle seal, you can pick up a cheap seal removal tool at a parts store for a few bucks which is a big metal hook with a handle.
[Re: 87Toy4x4]
#472508
07/05/04 12:43 AM
[Re: 87Toy4x4]
#472509
07/05/04 02:31 AM
the wheel bearing seal on the front hub assembly. i havent really tried it since then b/c ive been busy but is there any way w/o a tool?
[Re: 87Toy4x4]
#472510
07/05/04 05:09 AM
Yes. Just tear it up with a flat head screwdriver.
[Re: Adam F]
#472511
07/05/04 04:16 PM
The quick and dirty way is to put a piece of wood across the seal and pry with a screwdriver (using the wood block for leverage.) Just deform the sucker right out of there. Seals are a one shot deal so don't try to "save" it.
I prefer to use an actual seal puller which you can pick up cheap (under $10) from any autoparts store and will make your life a lot easier should you have to ever pull your inner axle seal.
#472512
07/05/04 05:28 PM
hit it out from the other side. USe something that will not scratch the housing. Its not that hard to get that foil seal out <img src="/forums/images/graemlins/drunk.gif" alt="" />
2006 tacoma SR5 4x4 V6 Auto
[Re: shawn p]
#472513
07/06/04 03:47 PM
A good way to hold the hub assembly is to put the hub assembly in the wheel with a couple of lug nut finger tight. Lay the tire face down. That will hold it while you pry the seal out. I use a pry bar and block of wood.
88 Xtra Cab, SAS, 35X12.50 MTR, Toyota E-Lockers front and rear, Rear seat, custom nerfs and rear bumper.
