'01 Runner Trouble - VSC OFF #473265 07/06/04 09:34 PM
OK, I'm new to the forum and have a question for the experts. I have a '01 4runner with roughly 70000 miles on it and this past weekend something interesting happened. I was driving through town and my check engine light came on along with the "VSC OFF" and "VSC TRAC" lights. Can anyone tell me what is causing this problem or possible fixes for this? I just want to get an idea of what I'm getting into before I take in to get it checked out. Thanks in advance for you help.
Senator1979
Re: '01 Runner Trouble - VSC OFF #473266 09/24/04 10:23 PM
Dbryan22 Offline
Senator, did you ever find out what was the problem?
2001 SR5 4Runner 4x4
Re: '01 Runner Trouble - VSC OFF [Re: Dbryan22] #473267 10/01/04 12:43 AM
philbertgranger Offline
Exact same thing just happened to me today. I'll let you all know what it is when I get it back from the dealer.
2001 Silver 4Runner, Nokians, Thule rack
2003 Red Tacoma Extended Cab, V6, 5-spd
Re: '01 Runner Trouble - VSC OFF #473268 10/01/04 01:11 PM
W
Woodsie Offline
When my '02 4Rnr was about 3 months old, that happened.
Took it to the dealer. Gas cap wasn't tight enough.
They reset it.
Re: '01 Runner Trouble - VSC OFF [Re: Woodsie] #473269 10/01/04 11:01 PM
Good call, Woodsie. The check-valve in my gas cap was bad. Could've been a lot worse. Thanks.
Re: '01 Runner Trouble - VSC OFF [Re: philbertgranger] #473270 10/05/04 12:59 AM
Dbryan22 Offline
From my trip to the stealership...
"Scanned system and received fault code P0446. Fault traced to EVAP canister malfunction. Removed and replaced EVAP canister assy as needed."
Labor: $212.50
Parts: $338.84
Total: $599.59
<img src="/forums/images/graemlins/frown.gif" alt="" />
Re: '01 Runner Trouble - VSC OFF [Re: Dbryan22] #473271 10/05/04 01:40 PM
W
Woodsie Offline
Man,
Did you have to pay for all that or was it under pollution control warranty?
Re: '01 Runner Trouble - VSC OFF [Re: Woodsie] #473272 10/05/04 09:58 PM
Dbryan22 Offline
Nope, I paid through the nose. Federal warranty is 3/36k. Calif warranty was 5/60k but I am in NY. <img src="/forums/images/graemlins/angry.gif" alt="" />
Re: '01 Runner Trouble - VSC OFF [Re: Dbryan22] #473273 10/06/04 12:54 PM
W
Woodsie Offline
Dbryan
You might want to check into that coverage a little farther. I found this;
Federal Emission Coverage: Components under the federal emission defect warranty are covered for 3 years/36,000 miles from the date of first use and specified major emission control components are covered for 8 years/80,000 miles from the date of first use. Specified major emission control components under emission performance warranty are also covered for 8 years/80,000 miles from the date of first use. In addition, emission performance warranty is applicable for 2 years/24,000 miles from the date of first use in states and local jurisdictions that require a periodic EPA-approved inspection and maintenance program.
Re: '01 Runner Trouble - VSC OFF [Re: Dbryan22] #473274 10/16/04 04:08 PM
4
4xGeek Offline
Labor: $212.50
Parts: $338.84
Total: $599.59
Damn... That is one expensive charcoal-filled plastic box! (yep, that's all it is) Did that labor amount include their 'diagnostic' time as well? I ask 'cause it takes all of 10 minutes to pull & replace (while drinking a beer)... <img src="/forums/images/graemlins/rolleyes.gif" alt="" />
Did you ask for the old parts back? If so, was it cracked?
4xGeek (Chris)
'97 T-100 4wd sr5-suto, 3" BL, 1.5" BJ spacers, 35" ProComp AT's, 4.88's, Bilsteins x 6, etc...
No longer stuck in SoCal!! smile
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.005s) Memory: 0.6352 MB (Peak: 0.7568 MB) Data Comp: Off Server Time: 2026-06-10 01:44:21 UTC
