Can I fit 33's on my 86 sr5. #473619 07/07/04 06:30 PM
G
GMJK86SR5 Offline OP
I would like to get some 33's for my 86sr5ext. I have the stock rims, 1.5" spacer in the front and 2.5 inch shackles in the rear. would they fit under the fenders?
Mike
Re: Can I fit 33's on my 86 sr5. [Re: GMJK86SR5] #473620 07/07/04 07:06 PM
4Crawler Offline
It'll be close, if you run stock rims and 33x10.50 tires, it should work, likely will need to do the fender seam flatting and other minor trimming as needed. For 33x12.50s, may need some more work:
Tire Fitment Info.
Re: Can I fit 33's on my 86 sr5. [Re: GMJK86SR5] #473621 07/08/04 03:54 AM
Winch Offline
Mike
If I understand you correctly, a 1.5" tall spacer will give you almost 3" of lift (due to pivoting), and shackles that are 2.5" longer than stock will give you 1.25" of lift in the rear (once again as a result of pivoting), so 33's should fit easy in the front, but not so easy in the rear. Also, you need at least 7" rims for 12.50 wide tires.
'02 Double cab, 5 speed swap, dual T-cases, FZJ80 SAS, E-lockers F/R, 37" MTR's
http://winchstoyotaparts.yolasite.com/
Re: Can I fit 33's on my 86 sr5. [Re: Winch] #473622 07/08/04 04:24 AM
4Crawler Offline
I assume this is a ball joint spacer ('86/IFS) so lift should be 1:1, it just lowers the spindle 1.5", giving 1.5" of lift. Rear tire fitment is usually much easier, wheel well opening is plenty big for 33s and since they stay straight ahead, you don't have the steering issues like you do up front.
PHP: 7.4.33 Page Time: 0.008s Queries: 15 (0.006s) Memory: 0.6032 MB (Peak: 0.6591 MB) Data Comp: Off Server Time: 2026-10-26 04:14:15 UTC
