Wanna see what stock rear speaker pods look like?..... #474278 07/09/04 02:22 PM
A little over a week ago I had some questions regarding the size of the rear speakers. I was told by many folks that the rear stock speaker size is 5.25" which is wrong, they are actually 4" speakers. Anyways, heres the pods they go in. Inside the pods, there is an amp to power the speaker. There are two these back there, one on each side.
Hope this helps someone,
Lyle
PS: I also wanted to add this: I replaced those rear speakers with some Sony Xplod 2-Way 5.25" speakers, I must say the factory 4" speakers blow these away. If I would have known this, I would have never messed w/ those pods (had to cut them to get the new speakers in.) and would have put some new speakers up front (3.5") instead. Learn from your mistakes, learn from your mistakes <img src="/forums/images/graemlins/lol.gif" alt="" />
PSS: I dont see anyway that a 4" speaker could fit up front, only a 3.5" speaker will fit. But then again, maybe I am wrong.....
Re: Wanna see what stock rear speaker pods look like?..... #474279 07/09/04 06:58 PM
<img src="/forums/images/graemlins/confused.gif" alt="" /> Yeah, my '97 LC has a similar set-up in the rear doors. Now, I have to figure out how I can mount aftermarket 3.5" - 5.25" speakers using the existing mounting pod.
Someone might make adapters to mount aftermarket speakers or maybe I can fabricate something to mount them.
Re: Wanna see what stock rear speaker pods look like?..... #474280 07/10/04 07:40 PM
Sid's Toy Offline
that amp also powers the power intenna I beleive.
I broke the power intenna off wheeling one night and cut the wire so the intenna would go up or down and the rear speakers went out. Put a basic intenna on and reconnected the wires and the speakers were back on.
Sid
92 4Runner SR5 3.0 standard tranny
4.88 gears, rear elocked, OME coils, SAW Tbars, allpro rock sliders and rear bumper, custom made front, downey v6 headers ...
Re: Wanna see what stock rear speaker pods look like?..... [Re: Sid's Toy] #474281 07/13/04 11:56 PM
Actually, a 4 in. speaker does fit up front in the 2nd gen 4Runners, but you have to make sure you find one that is shallow enough. I have a pair of Infinity 4 in. speakers up there and they fit reasonably well. I did have to heat and pound the enclosure for the driver's side speaker in order to make the speaker sit flush in that casing. Very easy to do, even with a lighter.
Better yet, if you find a shallow 6 in. speaker they WILL fit in the front doors of the 2nd gen. It does require some careful measuring and cutting of the stock door panel, but the results blow away the pitiful 4 in. speakers by themselves. I have a pair of Infinity Kappa's in mine. You also have to relocate the map pockets, but that's an easy task -- shift the back about 10 inches and there are screw holes to mount them at that location. The rear speakers are a total waste -- too far away from the driver to do anything more than provide "filler" sound. Don't waste your money upgrading those unless you're going to do a custom enclosure in those panels and add a couple of small subs (next on my audio project list).
Ed
Re: Wanna see what stock rear speaker pods look like?..... #474282 07/15/04 12:36 AM
BrownBox Offline
My MR2 turbo also had a similar 'subwoofer' setup behind the drivers seat. I managed to blow that speaker and rather than replace the factory one I bought an 8 inch rockford fosgate sub (not amplified) and box that I wired directly to the wires from the stock sub. This setup worked well in the MR2 and I yanked the box out when i sold the car. I wonder if I can do the same with the 4runner? If those little boxes are amplified, maybe I can unhook one and add a little (better) bass?
Doug
95 Toyota 4Runner V6 auto
94 Chevy Z71
06 Arctic Cat 700 EFI
http://community.webshots.com/user/brownbox
Re: Wanna see what stock rear speaker pods look like?..... [Re: Sid's Toy] #474283 07/15/04 10:28 AM
sid
I think that you had something completly different going on when your intenna broke.
I took out the speaker pods in the back of my truck and put 6x9's in the back and my intenna works fine. <img src="/forums/images/graemlins/shame.gif" alt="" />
Re: Wanna see what stock rear speaker pods look like?..... #474284 07/15/04 03:22 PM
hmmm. i haven't taken apart the rear yet but i did replace my front speakers last summer
i bought a set of 4" Alpine speakers. Nothing special really. They fit in the speaker pods easily.
Re: Wanna see what stock rear speaker pods look like?..... #474285 07/16/04 01:22 AM
anthony1 Offline
Thanks for posting that. I've always wonder what's behind those grills. Have you taken it apart to see what's inside the box?
I wanna see what's inside that box.
If you dont't like religeous holidays, go to work.Otherwise, let's call them what they are.
It's freedom OF religion not from.
95-4R,SAS,f/r locked,35MT/R 5spd, 4:1,5.29. my site
PHP: 7.4.33 Page Time: 0.011s Queries: 15 (0.008s) Memory: 0.6127 MB (Peak: 0.7100 MB) Data Comp: Off Server Time: 2026-11-02 19:22:51 UTC
