Needed: "Pulley Immobilizer" tool for 3.5L Timing Belt #474303 07/09/04 04:21 PM
Can anyone suggest where to get or what to use to hold the pulley in place while you loosen the bolt? The Helm service manual lists a very nice looking specialty tool which of course I cannot get at my local Autozone. Anyone who has done this have any suggestions?
Also while I'm on the subject: The timing belt is coming off in order to replace a blown head gasket. The same service manual specifies a special tool to remove the head bolts. Does anyone have any experience with this and can tell me if the bolt heads are splined or allen-style?
I've searched for related posts and found nothing -my bad if I overlooked something.
Thanks in advance!
Re: Needed: "Pulley Immobilizer" tool for 3.5L Timing Belt #474304 07/09/04 04:51 PM
Ed C Offline
crank pulley tool
PM Taro and Nazrat- they might know of its whereabouts.
Ed
Re: Needed: "Pulley Immobilizer" tool for 3.5L Timing Belt #474305 07/09/04 05:37 PM
sweater Offline
I don't know if this applies to the 3.5L, but it sure worked with my 2.6:
Get a breaker bar and socket on that bolt, brace the breaker bar on the side of the engine bay, and tap (only tap! do not keep cranking!) the ignition key/starter to turn over the engine. This forces the engine to turn over, but doesn't allow the bolt to spin, thereby loosening that bolt.
For the 2.6, the engine wants to spin clockwise as you're looking at it from the front. I don't see why you couldn't use this technique with your engine...
Re: Needed: "Pulley Immobilizer" tool for 3.5L Timing Belt #474306 07/09/04 07:03 PM
I had a friend fab me a spanner for this purpose. Piece of plate steel with a hole in the center to allow socket access, welded to a piece of plate (~2" x 24") as a handle, two bolts welded to the lower plate to fit in the bolt holes on the pulley.
Re: Needed: "Pulley Immobilizer" tool for 3.5L Timing Belt #474307 07/10/04 06:47 PM
Dark_Angel Offline
I did it the good old fashioned way. Get a friend. Pull the 4 10mm bolts off the torque converter dust cover. Use a largeflat head screwdriver or prybar into one of the teeth on the flywheel and resting against the houses. The other person breaks the bolt loose.
For the head bolts. It's a 10mm allen bit. I basically got a metric allen set, Cut the thing down and welded it to a 10mm 1/2 drive socket and used a breaker bar to looses all the bolts. The welding is optional. I found it made my life a little easier.
2000 Trooper 4x4, Auto, TOD pretty much stock at the moment.
2001 Camaro Z28, M6, fully loaded and too many mods to list! AKA Dark Angel
PHP: 7.4.33 Page Time: 0.008s Queries: 14 (0.005s) Memory: 0.6016 MB (Peak: 0.6642 MB) Data Comp: Off Server Time: 2026-06-17 03:26:01 UTC
