Adapting a 4cyl. t-case to a R150F tranny Q's #474675 07/10/04 07:01 AM
914Runner Offline OP
If I wanted to replace my chain drive t-case with a gear drive 4cyl. t-case on the end of my R150F tranny I would need the following, correct?:
- V6 Adapter Plate From Marlin Crawler
- 4cyl. Top Shift T-case
- 23 Spline Input for 4cyl. T-case
Thanks for the help!
1991 Toyota 4Runner 4 Door, 3.4l 5VZ-FE Engine Swap, R150F 5-Speed Manual, 4WD, 4.10's
My Rig
Re: Adapting a 4cyl. t-case to a R150F tranny Q's [Re: 914Runner] #474676 07/10/04 02:43 PM
bwhitehead Offline
Sounds about right. Are you going 4.7 or duals. I have duals and love them way more control and better selectablity.
93 4Runner 3.4 swap, SAS, 37 Mtr, 5speed swap, High pinion ARB Front an Arb rear, ARB air compressor, Marlins Dual cases, bud built crossmemeber, 63 leaf spring swap. Sky rear disc conversion and the money keeps flowing!
Re: Adapting a 4cyl. t-case to a R150F tranny Q's [Re: 914Runner] #474677 07/12/04 02:58 PM
Red_Chili Offline
Toyota Section Staffer
Yup. If you get lucky and find a turbo truck transfer case, you won't even need the 23 spline input shaft/gear.
You might need to adjust driveshaft lengths, budget for that too. The adapter adds a little to the transmission/transfer case assembly length.
If you go dual cases you need another 23 spline. You can live a little on the edge and use Marlin's new design 21 spline input, but if you are changing it, you might as well go 23 spline throughout and fuggedaboudit.
-Bill
Re: Adapting a 4cyl. t-case to a R150F tranny Q's [Re: 914Runner] #474678 08/12/04 02:04 AM
dildinon Offline
if you're only going to be running one case you shouldn't need to modify your driveshafts. i asked about that and was told the 4cyl case plus adapter was only about 1/2" longer than the 6cyl case.
Davin Nisser
'94 Pickup Xtra Cab Deluxe 3.0 V6 5spd...'84 lwb frame swap with 2" body/drive train lift and solid axle in the works...
Re: Adapting a 4cyl. t-case to a R150F tranny Q's [Re: Red_Chili] #474679 08/12/04 04:19 AM
DirtyHarry Offline
Toyota Moderator
Or you can just buy 23 spline 4.7 gears. With the 23 spline input gear costing $125 and the 4.7 gears around $350 now, I would just get the lower gears.
Re: Adapting a 4cyl. t-case to a R150F tranny Q's [Re: DirtyHarry] #474680 08/12/04 09:43 PM
dildinon Offline
where can you get the 23 spline input gear for $125? the cheapest place ive seen them is from marlin for $180.
Davin Nisser
Re: Adapting a 4cyl. t-case to a R150F tranny Q's [Re: dildinon] #474681 08/12/04 11:26 PM
DirtyHarry Offline
Toyota Moderator
Sorry that number was off of the top of my head. Marlin and Inchworm are the best sources, but you may be able to find someone with a turbo truck who has installed low range gears and has the stock gears lying around.
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6200 MB (Peak: 0.6943 MB) Data Comp: Off Server Time: 2026-05-29 22:21:00 UTC
