What is the correct MPH correction for switching to 31inch tires? #475243 07/12/04 05:09 PM
TeaQue Offline OP
I threw some 31x10.50 BFG A/Ts on my monty a few weeks ago...
Is the speedo going to be off since these tires are bigger (even if not much) than the stockers?
1997 Montero LS
3.5 V6
31x10.5 BFG A/T's
T-bar lift
Optima Yellow Top
Cheap Pilot Fog lights
Re: What is the correct MPH correction for switching to 31inch tires? [Re: TeaQue] #475244 07/12/04 05:17 PM
Lloyd Swartz Offline
Hard to say, that is the stock size for Gen IIs, SRs. I would guess if it is off, you could procure a SR speedo gear to correct.
Re: What is the correct MPH correction for switching to 31inch tires? [Re: TeaQue] #475245 07/12/04 06:29 PM
Alex Kogan Offline
It is really a matter of what do you dim as off. Car manufactures usually make speedometers that show speed higher than the actual one (sometimes up to 10%, one of the reasons why you are not getting stoped going 5-10 mph above speed limit, is in fact you might be actually going just above or below one.). That means now with larger tires speedometer may show a correct speed. For example after going from 31 to 33" according to GPS my speed is only 2-3 miles above shown on the speedometer at 70-80 mph.
I believe that in your case by going from 235s to 31s difference in measurements of speedometer will be about 5% which translates into only 4 mph of difference at 80 mph (I hope you usually don't go much faster than that). How it translates into actual speed only comparison with something like GPS can tell, (or a cop with radar, for the sake of it). Anyway I wouldn't worry much about changing your speedometer gear just adjust you habits slightly.
08 PowerWagon (stock!)
Re: What is the correct MPH correction for switching to 31inch tires? [Re: Alex Kogan] #475246 07/12/04 06:38 PM
TeaQue Offline OP
I never drive above 80mph in this thing <img src="/forums/images/graemlins/lol.gif" alt="" />
I usually stay below 75 as a matter of fact.
off-topic: I just noticed you're located in KC! I actually live in Blue Springs (20 minutes east of KC)
I've been wondering if there are places around here to do some wheeling (even if it's mild wheeling in my case <img src="/forums/images/graemlins/smile.gif" alt="" /> ) maybe we can meet up sometime.
Can you give me any info on this "KC4WD" club I saw on your picture page?
1997 Montero LS
3.5 V6
31x10.5 BFG A/T's
T-bar lift
Optima Yellow Top
Re: What is the correct MPH correction for switching to 31inch tires? [Re: TeaQue] #475247 07/12/04 06:54 PM
FrankR Offline
What was your OE stock tire size? And was the speedo accurate with stock tires?
Frank
Re: What is the correct MPH correction for switching to 31inch tires? [Re: TeaQue] #475248 07/12/04 07:27 PM
LRJ4x4 Offline
borrow a GPS with WAAS correction <img src="/forums/images/graemlins/smile.gif" alt="" />
Re: What is the correct MPH correction for switching to 31inch tires? [Re: LRJ4x4] #475249 07/13/04 06:59 AM
Actually in my Gen I I found out that my speedo was off with the stock 235's and was only accurate once I had 31's (radar gun tested). Well, much closer to accurate. Kinda interesting.
Re: What is the correct MPH correction for switching to 31inch tires? [Re: TeaQue] #475250 07/13/04 09:54 AM
Skinnybloke Offline
Yeh, the speedo will be off.
Compare the revolutions per mile/kilometre for your old tyres, with the revolutions per mile/kilometre for your new tyres (these can be downloaded from the manufacturers website).
Work out the percentage difference, and add that to the speedo's reading (carry a calculator until you the hang of it). IE: 60mph + 5% =63mph. after a while you remember the how much to add per 10mph's.
It's time for my pill now!
93, 3.0L LWB, Pajero. 200K klm,s.
91, Mazda Bravo
Re: What is the correct MPH correction for switching to 31inch tires? [Re: Skinnybloke] #475251 07/13/04 12:45 PM
LandRaider Offline
Just find on of those trailer things the police depts uses to scare people into slowing down, and camp it until you can make passes un inhibited, and test it out. 20-30-40-50-60, and make a % difference estimate from that.
You know what I am talking about. The radar trailer....Your speed is (and in huge block letters) 56
Re: What is the correct MPH correction for switching to 31inch tires? [Re: LandRaider] #475252 07/13/04 02:05 PM
This is an online calculator that I found helpfull
Tire change speedo calculator
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6409 MB (Peak: 0.7662 MB) Data Comp: Off Server Time: 2026-05-29 15:26:55 UTC
