Lift is destroying front end of my trooper #475276 07/12/04 06:28 PM
Dank4x Offline OP
Ok, so i lifted the front three inches and after that i have had to replace all four ball joints all tie rod ends cv boots, etc,etc,. Im wondering if there is something wrong with my front end, i know that cranking the t bars isn't the best for the suspension but i never hear anybody else talk about front end problems except for cv boots and joints, my ride is really stiff and i have no droop but my bars are not cranked to the max, can somebody help me out?
90 trooper. 3inch BL. 3inch Suspension, 33in BFG muds sitting on 15x8 rockcrawlers, roof rack, calmini front double tube bumper with two kc's, hypertech power chip, spare tire hi-lift mount,flipped lid with K&N drop in filter more to come
Re: Lift is destroying front end of my trooper [Re: Dank4x] #475277 07/12/04 07:20 PM
sweater Offline
Then I'm thinking your bars are as maxed out as you can get them. If you have no more droop, how can you crank your t-bars any more, other than to just put more tension on them?
Anyhow, you're talking about a 14-year-old truck here. Yes, lifting it puts more stress on the suspension and will wear out parts more quickly. So I think you're seeing that wear.
If you have no droop, I'd suggest backing off on the lift a little. What you're saying is that the truck is riding on the upper bumpstops (the ones on the a-arms), which isn't very good for ride quality and is probably an idication that you're a little high. A little less lift, a little less CV boot replacement, IMHO...
Hope that helps a little <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: Lift is destroying front end of my trooper [Re: sweater] #475278 07/12/04 07:39 PM
Dank4x Offline OP
im not riding on the bumpstops, there probably a inch or inch and a half of clearance left, thats why im puzzled as to why my front end is so stiff
Re: Lift is destroying front end of my trooper [Re: Dank4x] #475279 07/12/04 08:29 PM
Daniel_T Offline
Try cranking them back two or three turns and see if that helps the ride any. You will not lose much lift and it should help the ride alot. I know when I first lifted mine thre inches it was fine, then I turned it a couple more turs and it would beat you to death riding on hte road. So I turned them back and all is well.
As far as the boots, balljoints tie rods go it is like what was said. You are dealling with an older truck you are going to have to replace parts like that, that are aready wore out. I mean you didn't have to replace them more than once have you?
Later,
Daniel
"Thanks for the joy that you gave to me"
Re: Lift is destroying front end of my trooper [Re: Daniel_T] #475280 07/12/04 10:09 PM
Dank4x Offline OP
yeah i have, i have replaced the ball joints twice, its a pain cuz they are expensive and i always have to special order them, cuz nobody stocks isuzu parts
Re: Lift is destroying front end of my trooper [Re: Dank4x] #475281 07/12/04 11:20 PM
Daniel_T Offline
Funny cus I have the same trooper and I got my ball joints from advance auto parts here in town. Try them the had them in stock when I needed them.
Later,
Daniel
Re: Lift is destroying front end of my trooper [Re: Daniel_T] #475282 07/12/04 11:48 PM
Dank4x Offline OP
must be a colorado springs thing cuz they didn't have any in stock, same with auto zone and napa and everybody else
PHP: 7.4.33 Page Time: 0.012s Queries: 15 (0.010s) Memory: 0.6192 MB (Peak: 0.7102 MB) Data Comp: Off Server Time: 2026-07-15 18:36:58 UTC
