Supra LSD swap... #475783 07/13/04 04:23 AM
Who has done it? Do you have a write up on it?
I would like some more info... I am about to aquire one from an '88 MKIII.
I saw the one at 4x4 wire, but who else has done it? What parts did you use from what axle?
Re: Supra LSD swap... #475784 07/13/04 03:21 PM
ZUK Offline
mostly stock
Re: Supra LSD swap... [Re: ZUK] #475785 07/13/04 04:03 PM
Thanks... So to clarify I need:
From my 4runner: 3rd member, and gears (4:56)
From the Supra: bearings, races, and LSD
Re: Supra LSD swap... #475786 07/13/04 04:07 PM
Staceman Offline
Also, don't forget gear oil, and a small tube of LSD additive. <img src="/forums/images/graemlins/coolg.gif" alt="" />
Re: Supra LSD swap... [Re: Staceman] #475787 07/13/04 05:30 PM
next question since we got all the parts listed...
Is it worth doing this mod? I orginally had plans for Dual ARBs in my 4Runner... BUT now I am thinking ARB up front, Supra LSD in the rear. My 4Runner is a daily driver, I make long trips on the highway.
My trail riding is something I know that won't give me any body damage or break any parts. I have to work the next day and the 4Runner is my only transportation.
I would like something to help me out in snow and ice... but also help out on the trails.
So what do you think I should do?
Dual ARB
OR
Front ARB and Rear Supra LSD
Re: Supra LSD swap... #475788 07/13/04 05:51 PM
G
Greg_Canada Offline
I'm doing front LSD rear ARB in my truck (but i plan a SAS in a few years)...
89 4Runner
Re: Supra LSD swap... [Re: Greg_Canada] #475789 07/13/04 08:06 PM
Staceman Offline
If I had the $$$$$$, Dual ARB it would be for sure! But, my budget, (and wife) only allows so much. I ended up with Supra LSD rear, Cheezy lunck-box locker in front (solid axle, '85 4Runner). Compared to open diffs, this truck has improved a ton. LSD in rear feels invisibe, but I know it works on the trail!
Re: Supra LSD swap... [Re: Staceman] #475790 07/13/04 10:59 PM
LSD is not a true locker.. one wheel will spin if in mid air. a waste b/c you'll still end up getting stuck if you ever go into anything midrange to hard. also, midrange trails are sometimes have hard spots.
Re: Supra LSD swap... #475791 07/13/04 11:10 PM
toy283 Offline
I think he'll be fine. He already stated he isn't into the very difficult trails. A front locker will do quite a bit to pull him through even if a rear tire is off the ground.
Dave
'84 X-Cab supercharged 283 V8, SM420, dual cases, etc.
'85 4Runner
Re: Supra LSD swap... #475792 07/14/04 01:15 AM
elripster Offline
I'd put the LSD in the front and ARB in the back. When climbing, where you need the locker, the rear of the truck has vastly more traction than the front. Also, a locked up front increases the chances for breakage where locking the rear axle for the most part does not.
Frank
1994 4runner, 3.0, auto, 4.88's, 31's, BJ spacers, Coil spacers, air shocks, D-ring anchors, 4Crawler F/R swaybar discos.
www.sdori.com
PHP: 7.4.33 Page Time: 0.009s Queries: 16 (0.006s) Memory: 0.6315 MB (Peak: 0.7540 MB) Data Comp: Off Server Time: 2026-10-24 13:10:37 UTC
