In advance: Thank you to anyone who helps out on this issue, i really appreciate any info
Problem: Truck started having intermittent starting problems where power would instantly 'click off' Put key in ignition, go to turn truck over and instead get a 'click' (sounds like a fuse shuts something off) and power dies to the dash/ gauges/lights. Turn key off, and go to turn back on but battery gauge reads nothing, no power shows up anywhere. Let the truck sit for a little while and come back, put key in, turn to on, and power shows up regular strength again. If i attempt to start the truck the same thing listed above happens again.
The truck USED to be able to be jump started, but that no longer is an option. If i hook cables up to it, i can turn the truck over for as long as i want, but it sounds weak, as if it's not getting enough power to crank over. Battery is new'ish, and i have charged it and it reads strong (outside of the truck).
The problem originated from having corosion on the battery/terminals (i think). Ive had non-starting problems that were fixed before by just wiggling the battery cables on the battery.
I'm hoping/thinking that this could be a starter problem, but don't know quite how to troubleshoot this issue. Battery seems fine, cables could/should probably be replaced, (they look old), haven't looked at the starter at all, and don't know how to tell if it would be an ignition switch problem.
Thanks again for any input!!
