91 explorer axle question #476892 07/16/04 06:38 AM
i have a 91 explorer sport and i plan to put a 5.5in lift on it. i was wondering if anyone knows how big i i can go with tires with out toasting the axles. stock tires are 235/70/15 so is 33in. too big? also if anyone knows of a good site with just general information on explorers i'd appreciate it if you'd let me know about it.
Re: 91 explorer axle question #476893 07/17/04 04:43 PM
DennisThompson Offline
Your Explorer has a 8.8" rear axle and a DANA 35 in the front TTB. I've seen lots of explorer's on 33s and both axles according to one of the 4x4 mags I read (I can't rember which one) will hold up to 33s just fine. You may want to upgrade your brakes though. I would also swap the Ford hubs for the Warn replacements if your going to use 4wd alot.
Dennis
Re: 91 explorer axle question [Re: DennisThompson] #476894 07/18/04 05:36 AM
thanks for the info
Re: 91 explorer axle question #476895 07/22/04 03:54 AM
Nick26 Offline
the 8.8 is stronger than a D44 and will handle 35"+ pretty easily. The TTB D35 however will wear out pretty quickly with much over 33's. for more info about explorers check out www.explorerforum.com
Re: 91 explorer axle question [Re: Nick26] #476896 08/04/04 05:01 AM
Explorerguy Offline
I am running 35's on my Explorer with a superlift 5.5 lift and the only thing I have had trouble with is bearings in the front. I go thru about 3 sets in a summer. I also had to cut out a lot of the front fender and I still rub on some ruff stuff. If I really had the money I would build a 2-door, move the front axle forward so I would have room to put 38" tires under it. That was my goal until I was let go from my work and the new job doesn't pay as much so the Explorer is put on the back burner.
If I was you I would check out the www.explorerforum.com
forum, if I had it to do over or if I had the money now I would go with a solid axle instead of the superlift. There are a lot of guys that have done a swap with either older Bronco's or F-150 and cut the axle down.
Hope this helps
By the way on the Explorer4x4.com (same as the Explorerforum) I go by Perry so check it out and I think there are pics of my Explorer.
1994 Ford Explorer 5.5 Superlift, 35's no-slip in the rear, lots of custom parts ( sliders, tire rack & more)
2003 Kia Sorento
1987 Suzuki Samurai for our son and wife
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.5989 MB (Peak: 0.6607 MB) Data Comp: Off Server Time: 2026-06-22 02:42:14 UTC
