Re: KYB Monomax Gas Shocks ??'s [Re: bretwalda] #477134 07/19/04 01:56 AM
Augie Offline
I have a hard time installing them. They are very hard. At that time it seems tobe a good alternative than overly soft OME I put in before. That was before I reindex the torsion bar. It seem like it does get stiffer after that. The extension travel are too short to get comfortable ride anyway. I learn from my LC that I need at least 2 3/4" extension travel to get a good ride.
Why dont you try to uncrank the torsion bar for a while. Just remember how many turn so you don't have to do alignment again if you need raise it back up.
Re: KYB Monomax Gas Shocks ??'s [Re: Augie] #477135 07/19/04 04:36 PM
Multimetal Offline
Don't know about the Monomax, but on the Gas-a-justs I was able to compress the fronts under my body weight (195 lbs.) Had to hold them compressed with a piece of rope to install them. I had to use a long piece of wood as a lever to compress them up while they were still on the rig to replace a sheared bolt. They're pretty stiff, but give a great ride off-road!
85 Pickup, Desert tan spray job, 3" Rough Country lift, Marlin shackles+bumper, Chebby igniter, 33x10.5" BFG's
PHP: 7.4.33 Page Time: 0.020s Queries: 16 (0.014s) Memory: 0.5947 MB (Peak: 0.6593 MB) Data Comp: Off Server Time: 2026-11-02 03:00:15 UTC
