Isuzu Specific OBD-II codes
#477663
07/19/04 12:47 AM
I pulled some codes trying to resolve a problem that I have been having. I am having a difficult time finding what these codes mean to the Isuzu ECM. The codes are p1299, p1125, p1295, p1220, p1515, p1326. Some seem to be similar between different manufactures, although some are very different. Any thoughts?
Re: Isuzu Specific OBD-II codes
#477664
07/19/04 02:47 AM
I don't know if this helps, but on my 2000 Trooper the PCM is a GM PCM. The codes are GM codes. I have a scantool called EFIlive for my Camaro and it will pull the codes and tell me what they are for the Trooper also. It will also give me realtime data. Do you have the drive by wire Throttle body? Those are similar to the ones I had when I forgot to plug mine back in.
2000 Trooper 4x4, Auto, TOD pretty much stock at the moment.
2001 Camaro Z28, M6, fully loaded and too many mods to list! AKA Dark Angel
#477665
07/19/04 02:54 AM
[Re: Dark_Angel]
#477666
07/19/04 04:14 AM
Hey Guy's Thanks for the help, now to see if I can narrow it down a little.
'Do you have the drive by wire Throttle body?" Yes, it is.
Im going to start a new thred with the issues.....thanks agian.
#477667
07/25/04 05:15 AM
Don't know if it's too late but check this page out web page
"If i can't crawl over it, i'll fly over it" rubo
'96 Amigo 4x4, 3.2L V6, 4L30E, D44 rear, SOA, 1" BL, undergoing surgery. '00 Rodeo LS 4x4, 3.2L V6, OME 919 Springs, front cranked to match,1" BL, 265/70x16 Scorion A/T's.
