rear window broken #477734 07/19/04 07:09 AM
Vonka Offline OP
Its a 95 4runner and rear window switch wouldn't work to roll window down.What would you guys do to repair it.The other windows is working fine.
88 4x4 22re
86 2wd 1-ton 22re
91 2wd 22re
Re: rear window broken [Re: Vonka] #477735 07/20/04 08:26 PM
BrownBox Offline
Will the key switch in the tailgate work? If it's just the button on the console that isn't working I would start there and check the obvious. Make sure the switch is still plugged in and clean the contacts. Then get a voltage tester to be sure juice is getting to and through the switch and then to the tailgate.
Doug
95 Toyota 4Runner V6 auto
94 Chevy Z71
06 Arctic Cat 700 EFI
http://community.webshots.com/user/brownbox
Re: rear window broken [Re: BrownBox] #477736 07/20/04 11:41 PM
G
Germ Offline
Just went thru a similar problem with my 85.
Obviously have to check the fuses, and the common things like the window lock switch. If all those check out, then I would pull the switch.
On mine there was a 6 lug connector, and if I touched the connectors with a test light, the window suddenly worked. This could either mean the switch is bad, or you've lost the ground (which was my case). If that doesn't do it, you'll have to check the ECM, which on your truck should be in the driver side rear panel (behind the wheel well).
Feel/listen as someone flips the switch to see if your getting contact (hear the click of the relay). If your not hearing it, then your probably not getting power to the ECM.
If you get the click, but still no movement, try to jumper the hot wire on the motor to see if it is bad.
4crawler has an excellent write up on his site, and some wiring diagrams as well. 4 crawler
good luck <img src="/forums/images/graemlins/kewl.gif" alt="" />
Twenty years from now you will be more disappointed by the things you didn't do than by the ones you did.
85 4Runner, New motor, Dual cases, 4.88's, ARB's (F/R), 4" lift, 33's, Warn M8000#.
PHP: 7.4.33 Page Time: 0.021s Queries: 15 (0.017s) Memory: 0.5922 MB (Peak: 0.6451 MB) Data Comp: Off Server Time: 2026-11-03 17:11:00 UTC
