Re: Newbie related T100 questions
[Re: surlynkid]
#477889
07/20/04 05:27 PM
You cats are alright. I appreciate all the insight. I PM'd him a day or so ago in regards to his T. Wouldn't mind checking it out. I am in Minnesota, but have flown numerous times to get vehicles. Most recently to pick up a '98 jetta TDI. Diesel baby. Don't get me started.... <img src="/forums/images/graemlins/kewl.gif" alt="" />
Never-the-less, if you have other gotchas or what not, let me have it. What are the recommended timing belt/water pump change intervals?
Thanks again -keir <img src="/forums/images/graemlins/cheers.gif" alt="" />
#477890
07/20/04 06:20 PM
timing belt in the 60-100K range. i do the water pump at teh same time since it is only $100 and too big a PITA to dig back into it again.
Scott Landon 1995 T100 - total buildup underway 1988 4Runner (22RE, W56) - new DD 2005 Dodge CTD 4x4 - Tow Beast 1990 Spec Miata 2010 GT3 2013 E92 M3
[Re: surlynkid]
#477891
07/21/04 03:26 AM
you can get brackets to drop both corbeau and recaro buckets straight into the T-100. I put a bucket into my T-100, (left the right bucket inplace because it is comfy) and it was probably the best mod I have ever done, put over 20K miles on it and love it. You do want to try to find a dealer and try on the seats before you get them because there are some differences for each seat.
#477892
07/26/04 02:44 AM
All, I came across a '97 SR5 located at a Ford stealership. The particulars are such: 5spd Topper 164k miles and... BUCKET $6499 any concerns among the populus in regards to the 164k miles. Would it scare you? I think I may jump on this one, however, wanted to clear it with the experts and see what ya'll had to say. <img src="/forums/images/graemlins/kewl.gif" alt="" />
I sincerely doubt I will be able to find out serive history(TB, water pump). So, those repairs will be in my close future. Again, thanks in advance. I appreciate your help!
-keir
#477893
07/26/04 03:03 AM
I just paid 4500 for a clean '95 SR5 4x4 auto, a/c, power everything, etc. It has 255K miles and runs strong on all original motor and tranny, no leaks, no issues. 165K is nothing. I sometimes think I paid too much, but seriously the only issue is the little numbers on the dash, otherwise the truck runs and looks like something that cost 10 grand. <img src="/forums/images/graemlins/smile.gif" alt="" />
#477894
07/26/04 03:04 AM
Check it out.
Timing belt and water pump aren't big deal. Besides, our best source for parts is Gettel Toyota for the DIY.
Check Clutch-pedal bracket (check for crack at firewall/pedal). Check the steering shaft boot for rot. (minor)
Go take it out for a drive and offer them $6K.
I have factory radio/cassette and Factory CD changer in a box if you need it. <img src="/forums/images/graemlins/ignore.gif" alt="" />
Good luck! Keep us posted!
[Re: uzombie]
#477895
07/26/04 03:08 AM
I come from the honda and vw world where if you blow a timing belt, you break/bend valves. Not the case here? I hope to drive it tomorrow. I will let you know my findings!! Thanks to all. Keep that info coming. closed circuit to UZOMBIE, weren't you just telling me to try to find a 97-98!?! <img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" />
#477896
07/26/04 03:49 AM
I come from the honda and vw world where if you blow a timing belt, you break/bend valves. Not the case here? I hope to drive it tomorrow. I will let you know my findings!! Thanks to all. Keep that info coming. closed circuit to UZOMBIE, weren't you just telling me to try to find a 97-98!?! <img src="/forums/images/graemlins/kewl.gif" alt="" /> <img src="/forums/images/graemlins/smile.gif" alt="" /> the T100 is a non-interference motor. a broken timing belt will not bend the valves. almost all of the toyotas with an interference motor get a timing chain. i believe there is an exception or two, but not the T100.
[Re: uzombie]
#477897
07/26/04 01:44 PM
Uzombie, I have a Factory 3-in-1 that I would like to trade for a Factory AM/FM/CD setup so I can use the pocket space for my CB radio. Please let me know if your interested. Thanks. cymmgarcia@yahoo.com
[Re: cymmgarcia]
#477898
07/27/04 04:40 AM
IT won't do you any good. The top unit is the AM/FM Cass. The Bottom unit is the CD Changer (3 disc cart). It takes up both Slots as your 3-n-1 takes them up.
And Keir- 97 is good. 98 is good. I just think of them as better than 95-96 because you can't put the TRD Supercharger on the 3.4L 95-96 motors. But they are all good motors. (TRD and Toyota Emission changes are the reason for the SC issue).
