Headlights? #478404 07/20/04 09:24 PM
My headlights on my 2000 Kia Sportage were very dim, so i figured it was my battery...i replaced the battery and still they are the same. COuld this be a fuse or do i just need new bulbs? Any Suggestions? thanks <img src="/forums/images/graemlins/confused.gif" alt="" />
Re: Headlights? #478405 07/20/04 09:30 PM
kiasound Offline
Check for corrosion on the terminals. I have had mine go dim, and by just touching the connector they brighten right up, and after cleaning they have been good for the last 6 months. I'd also verify the condition of the ground wire behind the parking light on each side.
Re: Headlights? [Re: kiasound] #478406 07/21/04 01:26 AM
tlab Offline
I would assume that the problem with the headlights and the starter / ground connections or whatever the problem with the starting system are the same problem. I bet that when you get the starter problem fixed then the headlights will be magically cured.
2001 dodge dakota bone stock right now.
check out the last love of my life on .....
http://members.cardomain.com/tlab1
Re: Headlights? [Re: tlab] #478407 07/21/04 08:06 AM
fokion Offline
and since grounging is a known bug of the system, I wouldnt be surprized.....
Good point my friend <img src="/forums/images/graemlins/kewl.gif" alt="" />
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.5944 MB (Peak: 0.6520 MB) Data Comp: Off Server Time: 2026-06-23 14:18:07 UTC
