Does anyone run a Downey Exhaust system?? #478535 07/21/04 01:38 AM
I was looking at buying a Downey Exhaust System, part # 17484 for the price of $340.00 including the Cat,it's a 2.5" system. Does any one run one and how well do they work/sound? I'm a little leary of the 2.5", too much back pressure compared to the 2.25"!
I need a whole new system, plus my cat ran away somehow! <img src="/forums/images/graemlins/lol.gif" alt="" />
Thanks everyone!
* Harry * <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: Does anyone run a Downey Exhaust system?? #478536 07/21/04 02:03 AM
Terry4X4 Offline
I don't have any experience with the Downey system, but last year I replaced the Cat back and needed to reroute the exhaust anyway for the new rear shock mounts.
Installed I paid about the same with Cat, new Flowmaster 50 series muffler, and custom bent 2.25" pipe.
Semper Fi <img src="/forums/images/graemlins/patriot.gif" alt="" />
Terry Johnson
Gettin' Off 4X4 Club
'89 XCab SR5 V6 - D60 Hybrid SAS, Ultimate Marlin Crawler, Detroit rear, ARB front
'97 TJ - Atlas 3.8 Twin Stick, ARB F&R, custom rollcage
Re: Does anyone run a Downey Exhaust system?? #478537 07/21/04 02:26 AM
Brian894X4 Offline
I'm no fan of Downey. You could probably do much better having a local shop fab something up for you. One problem with the "one size fits all" exhaust set ups is that you won't get the clearance you could when someone is fabbing it up to your specs.
As for exhaust tube size, I run 2.25" from the header through the cat and to the muffler. From the muffler to the exit pipe I run 2.5" and it works really well.
I would spend the money on an LC Engineering header first, if your funds are limited.
Good luck.
Re: Does anyone run a Downey Exhaust system?? [Re: Brian894X4] #478538 07/21/04 04:18 AM
G
Greg_Canada Offline
Good luck.
He has a 3vze...
89 4Runner
Re: Does anyone run a Downey Exhaust system?? [Re: Greg_Canada] #478539 07/21/04 04:35 AM
Brian894X4 Offline
Good luck.
He has a 3vze...
Doh!!! <img src="/forums/images/graemlins/shocked.gif" alt="" /> <img src="/forums/images/graemlins/shiner.gif" alt="" />
Re: Does anyone run a Downey Exhaust system?? #478540 07/21/04 02:37 PM
ScaldedDog Offline
I've got Downey headers connected to a 2.5" exhaust (fabbed by Off Road Solutions) with a Random Technology cat and Flowmaster 40. It sounds much meaner than it is! People ask me all the time, "What do you have in that thing?", until they see me going up the pass at 60mph with my foot to the floor in 3rd gear - then they know.
I think 2.5" is just right for these things, and I've got good low-end torque. I can idle up steep climbs at 300rpm without ever stalling.
I'd suggest buying the Downey headers and having a good shop do the rest.
Just my $.02
Mark
''Wise men talk because they have something to say; fools,
because they have to say something.'' - Plato
http://www.scaldeddog.com
Re: Does anyone run a Downey Exhaust system?? [Re: ScaldedDog] #478541 07/21/04 02:50 PM
Red_Chili Offline
Toyota Section Staffer
Mark's truck does indeed sound nice. A little loud in the interior on the highway, but then so is mine these days...
2.25 has MORE backpressure than 2.5, not less.
-Bill
Re: Does anyone run a Downey Exhaust system?? #478542 07/22/04 12:40 AM
Snowtoy Offline
I am running the Downey exhaust(most of it). I have the Downey headers and X-over pipe, their high flow muffler that goes with their exhaust system, and the Magnaflow high flow cat(which I believe is the same one Downey sells, the item numbers in Downey's catalog are the same on the Magnaflow box). The system is all 2.5", you really don't want anything smaller 2.25. The exhaust tone is deep and throaty, sound more like a street rod, than an import. The sound is fine for a daily driver on th estreet, but I find it too loud for the trail, tends to get a bit obnoxious after a while. I plan to tone it down with a "Purple Hornie" muffler(I will put it in between the cat and the Downey muffler. This should tone it down enough, and I am hoping it adds to the back pressure some. With the current set-up system I have plenty of power in the higher RPM's (3300+), but the low end torque needs a little help. The Downey system may have all the torque needed on a truck at stock weight, but with mine at over 4900 lbs it seems I need a little more back pressure. If the Purple Hornie doesn't do the trick I will swap out the 2.5" cat for a 2" one. Before buying the Downey system, see what a local shop would charge. The local one I went to wanted $200 to from the headers to the Cat, Downey's X-over only cost me $179, and included the cat adapter w/O2 sensor mount.
Re: Does anyone run a Downey Exhaust system?? [Re: Terry4X4] #478543 07/30/04 07:56 PM
Ok, just got a new exhaust put on, new cat, pipes, flowmaster muffler, 2 1/4" all for the low,low price of $300.00 at my local muffler shop! <img src="/forums/images/graemlins/kewl.gif" alt="" />
Sounds awesome! <img src="/forums/images/graemlins/cheers.gif" alt="" />
That was much cheaper than $400 for just the parts from Downey!
* Harry *
Re: Does anyone run a Downey Exhaust system?? #478544 07/30/04 10:35 PM
Terry4X4 Offline
Nice. <img src="/forums/images/graemlins/kewl.gif" alt="" /> Which Flowmaster did you get? The 40 or 50 series?
Terry Johnson
PHP: 7.4.33 Page Time: 0.012s Queries: 16 (0.008s) Memory: 0.6410 MB (Peak: 0.7659 MB) Data Comp: Off Server Time: 2026-11-16 01:32:11 UTC
