1 ton rear end #42423 11/13/02 08:43 PM
toyrker Offline OP
In our local trader mag. their is an ad that reads: 1985 toy 1 ton complete rear end, geared extremely low. $90.00. Whats the scoop on these rears? Would it be worth inquiring about? Thanks!
85 4runner, 22re,cam, headers,2.25free flow exhaust,3"susp lift, 33's,custom bumpers,& stuff
Re: 1 ton rear end #42424 11/13/02 10:00 PM
Sounds like it's from a two wheel drive model.
Re: 1 ton rear end #42425 11/13/02 11:04 PM
toyrker Offline OP
Is it possible these are 8" gears? If not what are they? I suppose they came out of a camper. When you see something @ this price you have to ask. <img border="0" title="" alt="[Smile]" src="images/icons/smile.gif" />
Re: 1 ton rear end #42426 11/14/02 01:54 AM
have you called about the rearend?? ask the seller the ?'s and he might just know if it's a 8" ( which i think it is) or not..
Re: 1 ton rear end #42427 11/14/02 02:19 AM
toyrker Offline OP
No. I haven't called yet. Its long distance & 230 miles away. I just thought someone would know the specs. I have not got a clue. If its 8", do you think it would be adaptable to my application? Is it heavy duty like the 6cyl diffs? Or is the 1 ton bit in springs ? Thanks!
Re: 1 ton rear end #42428 11/14/02 02:31 AM
toy283 Offline
It should be a standard 8" V6 diff, dunno what ratio, maybe 4.56. The axle is spring-under but that's a relatively easy fix. The axle shafts would be 5-lug. If all you want it for is the diff, it might be worth your while to check it out. At least try and find out the ratio.
<small>[ November 13, 2002, 08:33 PM: Message edited by: toy283 ]</small>
Dave
'84 X-Cab supercharged 283 V8, SM420, dual cases, etc.
'85 4Runner
Re: 1 ton rear end #42429 11/14/02 02:40 AM
Brian894X4 Offline
</font><blockquote><font size="1" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">quote:</font><hr /><font size="2" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">Originally posted by toyrker:
<strong>No. I haven't called yet. Its long distance & 230 miles away. I just thought someone would know the specs. I have not got a clue. If its 8", do you think it would be adaptable to my application? Is it heavy duty like the 6cyl diffs? Or is the 1 ton bit in springs ? Thanks!</strong></font><hr /></blockquote><font size="2" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">For '85, the 1 ton axle was only available for the 4X2 on U.S. models. Foriegn models could get the 1 ton in 4X4. The difference between the two is that the spring perches are under the axle on the 4X2 and over the axle in the 4X4. The diffs on all 1 ton axles, should be the same 8" diff found in the 4x4. The diffs are the same 2 pinion. 4 pinion type diffs did not come out until '86, although anything is possible.
The 1 ton axle should be of the full floating type with permanant hubs in the rear. A very beefy set up. Personally, if your doing a build up and want to keep the rear the same width as the '85 and not use the longer '86 and newer 4x4 axles, it might be worth it to cut of the spring perches and weld them on top of the axle. Also, I'm not positive that the 1 ton had the spring under, it could have been a spring over as well, but I doubt it.
Also, if yours is an '85, it "might" be possible to just unbolt the full floating kit and just install that on your axle. I'm not quite sure how these are set up.
The available diff ratios for the 1 ton in '85, were 3.90, 4.10 and 4.30.
Good luck.
Re: 1 ton rear end #42430 11/15/02 06:07 AM
These are the dually axles, right? What is the width of the axle and can they be used with just single wheels? There is a beat up Toyota dually delivery truck around here that I keep thinking about asking the owner if he would consider selling if I could use the axle in my truck.
Re: 1 ton rear end #42431 11/14/02 11:24 PM
Yep, full-floating and spring under. We've got one in the family camper. It's pretty wide. The inner tires have the same track width as the front. They're those dually wheels with lots of backspacing. If you ran those wheels turned in, you could run single wheels and they'd follow the fronts. I guess you could turn the wheels out but they'd stick out pretty far--if you like that sort of thing. I'm not sure of the ratio on ours but it's probably under 4:1. And the engine's a 4-cyl so I think it'd have a 4-cyl 3rd member but I'm not sure. I really like that axle--I'm sure it'd be great on a trail rig. *SNAP* Oh darn. Just slide the old shaft out and slide the new one in!
Eric
Re: 1 ton rear end #42432 11/15/02 01:24 AM
toy283 Offline
Not all one-tons came with full-floating dually axles. My dad's old one-ton looked just like any other 2wd pickup, single wheels on a semi-floating axle. It was differentiated only by a heavier spring pack and an 8" diff. I'm also unaware of any 1-ton 4wd trucks in any year.
Dave
'85 4Runner
PHP: 7.4.33 Page Time: 0.012s Queries: 15 (0.009s) Memory: 0.6304 MB (Peak: 0.7526 MB) Data Comp: Off Server Time: 2026-11-18 03:26:43 UTC
