Eibach rear springs #480602 07/27/04 02:51 PM
wd8cdh Offline OP
Hi,
Does anybody know the free height of the Eibach rear springs? I think the stock rear springs are about 10.43".
Thanks.
Ron Schroeder
Long Island NY
99 4DR auto Sportage, 30x950R15 tires, 3/4" strut spacer, rear air springs, Manual Hubs, FRONT Torsen LSD
00 Safari AWD, 2" lift, 30x9.50 tires, 4x4 conversion in progress
73 Pinzgauer Swiss Army troop carrier
Re: Eibach rear springs [Re: wd8cdh] #480603 07/27/04 09:39 PM
tlab Offline
Don't know off hand but do a search for Eibach and check through the threads. I beleive it was posted in a couple of threads awhile back.
2001 dodge dakota bone stock right now.
check out the last love of my life on .....
http://members.cardomain.com/tlab1
Re: Eibach rear springs [Re: tlab] #480604 07/28/04 04:10 PM
wd8cdh Offline OP
Hi tlab,
I searched thru thousands of posts both here and on the Yahoo group and the only thing that I was able to find was a referance that they might be about 1" longer than stock. I was hoping to find something more definitive than that.
Ron Schroeder
Long Island NY
Re: Eibach rear springs [Re: wd8cdh] #480605 07/28/04 05:39 PM
Dave Scott Offline
i don't think their free standing length is much different from the stock coils, but they do have more winds in the coil and they have a higher rate, so once installed, they do not compress as much. not sure why you need the the free length measurement. so?
Re: Eibach rear springs [Re: Dave Scott] #480606 07/28/04 05:46 PM
wd8cdh Offline OP
Hi Dave,
For shock length and for air bladder sizing.
Ron Schroeder
Long Island NY
Re: Eibach rear springs [Re: wd8cdh] #480607 07/28/04 07:32 PM
Dave Scott Offline
what i think you mean is that you want to get a shock that will top out before the coils fall out? and an airbag that will not try to expand the coil further than it's free length? hmmmm... that could be difficult anyway. the only airbags i know of for the Sportage are for the stock coil height, which would work easily with a small spacer platform built up in the center of the lower coil plate, or something like that, for the airbag to sit on. as for the extension- well, i'am sure Dennis Thompson can attest to how much travel you can expect before the coil will fall out, in fact, he may still have his worn-out Eibachs to get an estimated measurement for you. PM him.
Re: Eibach rear springs [Re: Dave Scott] #480608 07/29/04 01:59 AM
DennisThompson Offline
I threw them out. I do know that with a 24" (if I rember right) shock and the 2" spacer the Eibachs will fall out at full extition. The Eibach ride height is 1 1/2" over stock in the rear so for new shocks I wouldn't go more the 2" over stock.
Dennis
Re: Eibach rear springs [Re: Dave Scott] #480609 07/29/04 01:34 PM
wd8cdh Offline OP
Hi Dave,
I am looking into both airbags to replace the springs and the airbags that fit inside of the coils. I have found bags that fit inside but are 2" longer than the ones that Airlift puts in their #60752 kit. I ordered a pair yesterday.
Out of curiosity, what is the free length of your 4" lift rear coils?
Thanks,
Ron Schroeder
Long Island NY
Re: Eibach rear springs [Re: wd8cdh] #480610 07/29/04 01:49 PM
Dave Scott Offline
honestly, i don't know- i have all the kits shipped directly from the coil maker to the buyer and mine are sagged, but i can give you an estimate when i get home. also, either Kungpow or Shifter26 took some pics of the coils with a tape measure through the middle- check with them.
Re: Eibach rear springs [Re: Dave Scott] #480611 07/29/04 02:08 PM
DamKia Offline
Kia Moderator
Stock springs free length is 10.6" if that is any use to you (just happen to have one next to me!!)
PHP: 7.4.33 Page Time: 0.010s Queries: 16 (0.007s) Memory: 0.6402 MB (Peak: 0.7638 MB) Data Comp: Off Server Time: 2026-11-16 01:26:50 UTC
