Hey guys, this is former "new toy", lost my password....
My 94 22re has recently started making a bunch of noise. It kinda sounds like a diesel when it's at idle, a kind of rattle. Using the screwdriver trick I haven't been able to find the origin specifically, but it may be coming from the valve train, it is also quite noticable under the truck.
History: Bought the truck in the spring with 130K. Engine sounded fine, except the timing chain made noise at start up so I did that with an EB steel rail kit. (BTW, Still makes the same noise at start upfor 2-3 sec with all new parts, I guess this is normal?)
It runs great, so I Drove it for awhile and all the sudden I would get this intermittent rattleing from the engine at idle. I changed the oil it it seemed to go away...for about 1000 miles, when it returned. Louder now, and almost all the time. Changed the oil again and it got a little better but still there, sometimes loud sometimes relatively quiet. I suspected valves, so I adjusted them. No change. What really gets me is that it comes and goes...and 99% sure it's internal.
Then I noiticed yesterday while tag saleing (lots of engine on and off at each stop) that on a restart when the truck has only been off for a short time, the engine knocks for a few seconds on the restart. Sounds pretty bad, then it goes away. Not the same noise as the rattle... but maybe related???
I was thinking oil pressure problem, so I installed a guage last night, and it seems ok on an initial look. On a cold start, pressure picks up to 60psi within a few seconds (shows 0 untill the t-chain slap subsides). Then after idle comes down it settles at about 35psi. It goes up to 80 or so when I give it some gas. I am getting concerned here...and am now worried about taking her on any trips far from home <img src="/forums/images/graemlins/frown.gif" alt="" />
Any ideas / comments? This is really beginning to piss me off, I just got it running great but if this #@$% keeps up, pretty soon I'm dump it and buy a new 04 taco....
