Rear ceneter bearing
#483307
08/02/04 02:51 PM
On my 98 T100 the rear drive shaft center bearing. How do you kow if it needs replacing? I have a annoying sqeak and i was wonding if it was from that
Re: Rear ceneter bearing
[Re: urso8up]
#483308
08/03/04 06:28 PM
[Re: urso8up]
#483309
08/03/04 07:18 PM
You didn't say why you think it is the bearing. Is the noise there constantly? The most common source of a squeak is the hood latch mechanism. It usually makes noise going over bumps but is hard to isolate. Try cleaning it off or hitting it with some Tri-Flo or something to see if that takes care of it.
1997 T-100 4X4 Xcab,Warn Hubs 02 Camry LE 2008 Yaris
[Re: garym]
#483310
08/04/04 01:04 PM
It is not a sqeak like it is more like a sqeal or metal griding. It only happens in reverse and tha tis all that is why i can not find it and was hoping for some help
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6018 MB (Peak: 0.6573 MB) Data Comp: Off Server Time: 2026-05-29 22:23:47 UTCValid HTML 5 and Valid CSS
