Front Wheel Bearings #483370 08/02/04 05:57 PM
W
Woodsie Offline OP
Anybody have a link to a schematic of stock front hub assembly for an '02 4RNR? Suspect front wheel bearing noise. Like to see whats in there before tearing it apart.
Re: Front Wheel Bearings [Re: Woodsie] #483371 08/09/04 03:23 PM
You will need a factory shop manual, a 30 ton press and all the associated stuff to go with it before you even attempt to dissemble the hub on your truck.
If you are certain that the bearing has gone bad, pay the dealer to do the work for you. Trust me on this one. I have done two myslef and if you don't have all the right equipement you should not attempt this job.
Gadget
Re: Front Wheel Bearings [Re: Woodsie] #483372 08/16/04 04:40 AM
larsdennert Offline
Like Gadget said. The front bearing are sealed and not serviceable like the Tacoma.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.004s) Memory: 0.5908 MB (Peak: 0.6439 MB) Data Comp: Off Server Time: 2026-06-17 11:52:07 UTC
