Front axle ideas #483592 08/03/04 03:50 AM
abnormaltoy Offline OP
Hey guys,
IÆm at the point now that I need to decide what IÆm going to do with my front axle. Separate from anything else, IÆm going to need a new drive shaft. My front axle is 3 inches forward of stock. IÆve lifted the truck 5 inches. Now, as I see it my choices are:
1. Rotate the front diff and get a cv drive shaft.
2. Get a LC hi-pinion diff, which would mean new gears and another locker.
3. Buy a FROR front axle housing and keep my gears and locker.
If you have any other ideas (short of going with a 44) let me know.
Another thing IÆve been thinking of is in-boarding my rear springs. Any thoughts on this?
A brief update on my progress (someday IÆll post pics on my web site).
IÆve got all the wiring out and ready to start rewiring. IÆve ordered a lifeline battery. I should get my f/r cross members back from the machinist today. The mount for my fuel cell is complete and ready to install. Basically I was being held up waiting for my x-members. When I get them I can weld them in, redo my steering box and drop in the engine. IÆm going to order my t-case stuff from Marlin this week.
Thanks for any ideas or feedback.
Mark
Re: Front axle ideas [Re: abnormaltoy] #483593 08/03/04 05:07 AM
Red_Chili Offline
Toyota Section Staffer
I really really like my LC high pinion. The driveline is about ideal with double cases and an 85 CV, still would be with a single though. I can drive in FWD and only get a slight torque steer effect. Smooth as silk and some additional clearance too.
You would most likely recoup some coin selling your 4 cyl third with locker.
The FRORF axle would be cool (I assume you would rotate the pinion on it) but $$$, and then you still have a 4cyl third.
-Bill
Re: Front axle ideas [Re: Red_Chili] #483594 08/03/04 05:40 AM
I know, it's that freakin' "cool" factor that's killing me! I think I'm leaning toward rotating it at the knuckles and fabbing up some new perches. I like to make things work and make 'em cool.
Mark
Re: Front axle ideas [Re: abnormaltoy] #483595 08/03/04 06:57 AM
I would go D44 again. The significantly decreased turning radius, as well as the width improvement, and ease of finding cheap parts at any auto parts store just makes it a convenient choice. The fact that my experience with it compared to my yota fronts was that it is much stronger in stock form, is an added bonus.
Re: Front axle ideas #483596 08/03/04 06:59 AM
One more thing. No more greasy closed knuckles to open up! I hated those things...
Re: Front axle ideas #483597 08/04/04 12:21 AM
kyle-22r Offline
i'd go for a hybrid axle. toy center section, d44 knuckles. you get more ground clearance, a drop out third member and open knuckles.
you can also have them built to use stock d44 shafts, since they'll work in a toyota carrier. the pressure angle on the splines is a bit different but if it really bugs you, you could always have moser or superior build you a new set <img src="/forums/images/graemlins/kewl.gif" alt="" />
'91 4x4 shortbed
22R-E, W56, the dd!
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.6084 MB (Peak: 0.6749 MB) Data Comp: Off Server Time: 2026-05-29 21:12:37 UTC
