Re: Front sway bar bind after torsion bar lift [Re: StreetbikeDepot] #483718 08/04/04 04:52 PM
FrankR Offline
I don't see any reason why that won't work - and maybe not put as much pressure on the links - so long as it doesn't bang into anything on upper movement. Looks like the connection could benefit from an additional washer and bushing between the spacer and the bar, though - maybe it's there and I can't see it.
Frank
Re: Front sway bar bind after torsion bar lift [Re: FrankR] #483719 08/04/04 06:06 PM
StreetbikeDepot Offline OP
I had to go out and look at it myself, in the pic it does appear not to have a rubber isolator on the drivers side. Its there though. In full droop there is ample room. I'll be offroad with it this weekend and parts check it. <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: Front sway bar bind after torsion bar lift [Re: StreetbikeDepot] #483720 08/05/04 07:15 AM
bretwalda Offline
The Gen2 has a post coming out of the arm to attach to ($33 each <img src="/forums/images/graemlins/barf.gif" alt="" />):
concreteprinter.com
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.005s) Memory: 0.6001 MB (Peak: 0.6693 MB) Data Comp: Off Server Time: 2026-06-09 22:01:40 UTC
