Newbie A/C Question #484125 08/04/04 06:40 AM
G
Got Yogurt? Offline OP
Does anyone know when the trooper started coming with the new type of a/c coolant instead of the old type (i.e. CFC-Free)? I'm in Canada so they wont let us fill up the old type, only the new type (I believe the old type is R12, and the new type is HC134a). Sorry the question is so vague, I searched and got now answer and thanks in advance <img src="/forums/images/graemlins/cheers.gif" alt="" />
Re: Newbie A/C Question [Re: Got Yogurt?] #484126 08/04/04 12:04 PM
1993 seems to be the transition year. My 93 Trooper has R-12 A/C, but many 93's have the R-134. Depends on what month the vehicle was built in 1993.
Re: Newbie A/C Question #484127 08/04/04 01:50 PM
Richard Saylor Offline
The easiest way to tell if it is r-12 or r-134a is to go out and look at the a/c lines. If the low side connector is threaded, then it is r-12. If the low side connector is a quick disconnect, then it is r-134a. If it is r-12, then you must 'techincally' get it vacuumed out by a shop that will reclaim it, then get you one of the retrofit kits that will adapt it to r-134a. It would also be best to replace the drier before you retrofit it, but most people don't and never see a problem, at least right away.
Had an 89 Isuzu Pickup
Had a 94 Mitsubishi Eclipse
84 Honda XL185S
Re: Newbie A/C Question [Re: Richard Saylor] #484128 08/04/04 08:48 PM
O
OffRodEO Offline
or just pop open the hood and look on the drivers side fire wall, it will say with a yellow sticker. You can have it switched to r-135a easily.
kevan
93 rodeo,3.2 manual, limo tint, nice sound system,keyless entry and a killer alarm, drop in K&N, 3 inch DOR lift, 32-11.50 BFG MT's, warn hubs zutah.com wheeler
WELLS FARGO BANK WILL RIP YOU OFF!GET OUT WHILE YOU CAN
PHP: 7.4.33 Page Time: 0.006s Queries: 15 (0.004s) Memory: 0.5945 MB (Peak: 0.6524 MB) Data Comp: Off Server Time: 2026-06-25 22:31:45 UTC
