One more question on type of oil in 3.2 #485354 08/06/04 09:16 PM
I know this has been discussed ad nauseum, because I've always read all posts regardless of applicability to my rig. But, that doesn't mean I remember all the details. So now that I have a 3.2, I want to get the correct oil into it. AFAIK, I should be using Mobile 1 5W-30 if I don't have the tick, and 0W-30 if I do...is that correct?
A search yielded inconsistent answers. <img src="/forums/images/graemlins/confused.gif" alt="" /> Something about full moons, summer solstices... <img src="/forums/images/graemlins/smile.gif" alt="" />
Thanks,
Phil
Re: One more question on type of oil in 3.2 #485355 08/06/04 10:30 PM
Mr. Mojo Offline
Thats a good place to start. Every engine is different when it comes to the infamous tick and oil consumption. In my case my Rodeo burns a little oil with the Mobil Synths and almost none with Castrol Synths and they both help my vehicle with engine noise. And then there are many people here who swear by the dino oils too. Yup inconsistent. Hope that didnt confuse you more.
98 Rodeo
00 4Runner
--I swear its just over the next pass !!--
--"Courage is something you can't be afraid to have." - Frank Burns
Re: One more question on type of oil in 3.2 [Re: Mr. Mojo] #485356 08/06/04 10:45 PM
A little more searching yielded a little more info., but I saw all sorts of oil weights mentioned (20W-50 and such) and it was just too much voodoo for me to make sense of. <img src="/forums/images/graemlins/smile.gif" alt="" />
BTW, I'm one of those who swears by synthetic oil (unless it burns/leaks faster than you can check and refill).
Re: One more question on type of oil in 3.2 #485357 08/06/04 11:13 PM
sweater Offline
I guess I've got it easy, then: I always get the tick without 0w30, so that's all I run.
Otherwise, I run 5w30 in my Trooper's 2.6, if that helps any...
Re: One more question on type of oil in 3.2 [Re: sweater] #485358 08/07/04 12:16 AM
i switched to mobil delvac 1300 15w40 diesel oil because it has more detergents and dirt carying capabilities.a friend who races solo2 in a 300zx runs the same and gets reg oil analisys and you wouldnt believe how clean it is even after 6k mi
Re: One more question on type of oil in 3.2 #485359 08/09/04 05:46 PM
A
anthonyn Offline
My 95.5 Rodeo also prefers thicker oil to keep the tick away. I just changed my oil this weekend to chevron delo 15w40. It has high detergent levels since it is rated for both diesel and gas engines. The engine is running smooth and quiet so far and with slightly better oil pressure. I also went with the purolater premium plus filter to get the balance btw better flow and pretty good filtering.
95.5 Rodeo, Auto, Dynomax muffler, modified air intake, Manik Nerfs, clear corners, JVC MP3 player ...babied and nurtured since birth
Re: One more question on type of oil in 3.2 [Re: anthonyn] #485360 08/10/04 02:47 AM
taro Offline
i experimented with mobil1 0w-40 in my engine during the last oil change. it's worked out okay so far, but the ticking seemed to return sooner than when i use the 0w-30. i was hoping that the "heavier" weight would increase oil pressure, but i could not appreciate any increase in oil pressure over the 0w-30. it fended off the tick longer than the 5w-30 typically does though. ymmv, hth
Re: One more question on type of oil in 3.2 [Re: taro] #485361 08/11/04 10:43 PM
I have been using Red Line 10-30 since 30K. I have almost 90K at this time. Ticking rarely occurs and disapears quickly at startup. My oil analysis shows wear numbers in single digit parts per million with an OCI of 7500 mi. I burn about a 1/3 to 1/2 QT every 4K mi.
My engine is however a 3.5L
PHP: 7.4.33 Page Time: 0.010s Queries: 15 (0.007s) Memory: 0.6187 MB (Peak: 0.7169 MB) Data Comp: Off Server Time: 2026-11-17 06:27:04 UTC
