Ball Joint Spacer Install Complete #485516 08/07/04 05:42 AM
SWORDFISH92 Offline OP
Well started on installing my 1.5 balljoint spacers today. Finished with the grinding, however I can't seem to gain enough clearance between the upper control arm and the balljoint to slip it back in with the spacer on top. Not anything like the clearance shown on this page http://www.amug.org/~sschaefer/san_diego_off_road_solutions_.html
How do I do this?
Thanks
1992 4Runner V6 SR5 4x4 Auto
-ARBequed, Geared, Lifted, Lighted, and Locked. 32 BFG KM's
Re: Help!!! Ball Joint Spacer Install [Re: SWORDFISH92] #485517 08/07/04 06:25 AM
Myredyota Offline
Try taking the nut off the top of your shock and the nut off the bottom of your sway bar end link and let everything drop down a little bit with a jack until it all slides in.
[color:"blue"]Carey[/color][b]
[b][color:"red"]89 SR5 Extended Cab 4X4 V6
[/color][color:"blue"]Don't forget to pay your taxes......
Millions of illegal aliens are depending on you!!![/color]
Re: Help!!! Ball Joint Spacer Install [Re: SWORDFISH92] #485518 08/07/04 07:20 AM
code33 Offline
Did you remove the tension on the torsion bars?
Re: Help!!! Ball Joint Spacer Install [Re: code33] #485519 08/07/04 06:12 PM
No, how would i do that? I have already knocked out the original studs, so i was thinking about putting the new ones in, and putting the tires back on the truck. then placing something between the upper control arm and the bumpstop. Hows that sound? Anything better/easier?
Re: Help!!! Ball Joint Spacer Install [Re: Myredyota] #485520 08/07/04 06:28 PM
BeaterToyota Offline
Yep, this is what I did. I also stuffed some scrap steel tubing between the upper A-arms and their bumpstops so that they wouldn't droop so much when I jacked the rig up. With the shocks disconnected at the top, and the upper A-arms wedged so they don't drop, the lower arms should drop more than enough.
Jason
'88 Toyota, flatbed junker, Inchworm dual cases, spooled rear.
Re: Help!!! Ball Joint Spacer Install [Re: BeaterToyota] #485521 08/07/04 07:07 PM
thanks alot, I'll let you know how it goes.
Re: Help!!! Ball Joint Spacer Install [Re: SWORDFISH92] #485522 08/07/04 11:50 PM
mt_goat Offline
93 4X4 ext-cab, auto, SR5, 3.4 V6, supercharged, 2.1" pulley, URD fuel mods, Aquamist WI, IPT valve body mod, dual cases, 4" superlift, Alcan springs, 33 BFG MT, ARB locked front & rear, 5.29 US Gears, RB 1" BL, 1.5" BJ spacers, TJM T-17, Warn m8000.
Re: Help!!! Ball Joint Spacer Install [Re: SWORDFISH92] #485523 08/08/04 03:26 AM
well I used a bottle jack to spread the upper control arms from the lower, slid the spacers in. Finise
Re: Help!!! Ball Joint Spacer Install [Re: SWORDFISH92] #485524 08/08/04 03:28 AM
Everyone, thank you for all your help. Made this job so much easier.
Thanks again,
Matt <img src="/forums/images/graemlins/cheers.gif" alt="" /> <img src="/forums/images/graemlins/kewl.gif" alt="" />
Re: Help!!! Ball Joint Spacer Install [Re: SWORDFISH92] #485525 08/08/04 03:36 AM
Oh and for reference: 32x11.50 BFG Muds on stock backspaced wheels (4.5) DO clear, but just barely. I will have to let ya'll know after I get it aligned.
PHP: 7.4.33 Page Time: 0.006s Queries: 16 (0.004s) Memory: 0.6364 MB (Peak: 0.7595 MB) Data Comp: Off Server Time: 2026-06-17 11:59:44 UTC
