Re: Help!!! Ball Joint Spacer Install [Re: SWORDFISH92] #485526 08/08/04 04:37 AM
Myredyota Offline
Don't be afraid to grind down the lip on the upper control arm. It will give you a little more space. <img src="/forums/images/graemlins/butwiggle.gif" alt="" />
[color:"blue"]Carey[/color][b]
[b][color:"red"]89 SR5 Extended Cab 4X4 V6
[/color][color:"blue"]Don't forget to pay your taxes......
Millions of illegal aliens are depending on you!!![/color]
Re: Help!!! Ball Joint Spacer Install [Re: Myredyota] #485527 08/09/04 04:16 PM
I have 33x10.50 on the stock Yota rims. I do have a picture.
IF Pic doesn't work: http://memimage.cardomain.com/member_images/3/web/483000-483999/483537_20_full.jpg
Re: Help!!! Ball Joint Spacer Install #485528 08/10/04 02:49 AM
914Runner Offline
wvuviv30 - about how much clearence do you have, its kinda hard to tell from the pic.
Thanks
1991 Toyota 4Runner 4 Door, 3.4l 5VZ-FE Engine Swap, R150F 5-Speed Manual, 4WD, 4.10's
My Rig
Re: Help!!! Ball Joint Spacer Install [Re: 914Runner] #485529 08/10/04 09:29 PM
Thanks
Picture taken at ride height, with my buddy's camera phone, it's about 3/8-1/2" at ride height, 1/4-3/8" a full drop.
Re: Help!!! Ball Joint Spacer Install [Re: SWORDFISH92] #485530 10/04/04 02:25 AM
A
allochris Offline
So, just to make sure, do 32x11.50 BFG AT fit with no rubbing with & without the balljoint spacer? On stock wheel (don't know how much backspacing I have) & stock suspention on a 91' x-cab?
THanks
91-22re(408xxxkm & counting with a rebuilt long block)- Flatbed/Camper
/33x10.5BFG-AT/Open 4:88/1.5"BJS/
+2"Shackles/Add-a-Leaf/AirLift/Dual-Batteries
Re: Help!!! Ball Joint Spacer Install [Re: allochris] #485531 10/04/04 03:19 AM
SWORDFISH92 Offline OP
My 32x11.50 bfg muds fit before the install with stock backspacing. after the install and the alignment they still fit, the only thing i wasnt sure about was the stock backspacing, but they work just fine
1992 4Runner V6 SR5 4x4 Auto
-ARBequed, Geared, Lifted, Lighted, and Locked. 32 BFG KM's
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.005s) Memory: 0.6160 MB (Peak: 0.6976 MB) Data Comp: Off Server Time: 2026-06-17 06:49:10 UTC
