Downey Rear Coil Springs #487870 08/12/04 04:22 AM
G
Golden Dragon Offline OP
I just put the aftermarket coil springs and the body roll has improved but every time I hit the speed bumps, the back bounces like CRAZY. It feels like there are no shocks back there. Bilstein does not make shocks for the Downey springs ( being developed I guess). What rear shocks should I get? I also want to change my radiator. Which is the most popular aftermarket rads out there for second gen 4runners?
Right of The Line
Re: Downey Rear Coil Springs [Re: Golden Dragon] #487871 08/12/04 08:27 AM
Jeff the marmot Offline
You can find a radiator at www.radiatorbarn.com or other places.
Even though I have a 3rd gen and you have a 2nd gen, I can relate to talking to Bilstein to ask them about availability of their shocks for lifted vehicles. Their official position is they only make shocks for stock height vehicles. They were surprisingly insistent about that when I talked to them. If you do a search on this forum or on the 4wheeling forum, you might be able to find the model number of shocks that other people are using. There's probably several brands of shocks that work with lifts, too.
Jeff
2000 4Runner SR5, supercharger, rear e-locker, ARB front locker, 285/75R16 MT/R's, custom bumpers & skids
2007 Tacoma double cab 4x4 - stock
Re: Downey Rear Coil Springs [Re: Jeff the marmot] #487872 08/12/04 04:00 PM
G
I just ordered a 3 core radiator from the BARN for 127+. That's pretty good price I thought. Now I need to check if OME shocks will work with the Downey springs. I should have bought the whole OME package. I still can't find a shop (in my area) that installed a snorkel.
Thanks for the tip Jeff
Right of The Line
Re: Downey Rear Coil Springs [Re: Golden Dragon] #487873 08/12/04 06:56 PM
Robinhood150 Offline
I'm pretty sure lots of people just use the stock replacement bilsteins for the 2nd gens.
I'm using the stock replacement rancho 9000s
Steve
My Website ||Gettin' off 4wheel drive club member
'93 4Runner V6 4x4 auto tranny
If you have to ask about a SAS, you're not ready for it.
Re: Downey Rear Coil Springs [Re: Golden Dragon] #487874 08/12/04 08:00 PM
code33 Offline
I use slightly longer KYB's; Part number KG5561. They are great with the Downey coils. I have since added a spacer.
See what other's have done:
http://www.4x4wire.com/toyota/4Runner/tech/suspension/
Re: Downey Rear Coil Springs [Re: Golden Dragon] #487875 08/12/04 08:22 PM
TRDSR5 Offline
I ran the Deutchtech's from Downey that provide for the added lift. Any good shock maker should be able to look up the original shock then using their spec sheet find one thats another 1.5" longer.
From your description I take it you got the heavy duty springs? Even with good new shocks the ride is very harsh especially on speed bumps. When I tow it rides very nice. If I unload the tools from the back it absolutely rattles your teeth. Nature of the beast.
Turn LEFT to go RIGHT
Thudump!....What was that daddy? Ran over a Honda, go back to sleep sweety.
PHP: 7.4.33 Page Time: 0.007s Queries: 15 (0.005s) Memory: 0.6104 MB (Peak: 0.6805 MB) Data Comp: Off Server Time: 2026-06-23 00:45:01 UTC
