22r running rough at idle #488178 08/13/04 12:49 AM
Stinson Offline OP
Ive got an 86 22r that just recently started running rough at idle. It kind of sits there and lopes, or sputters. Almost like its missing. Soon as you get on the gas it smooths out fine. The exhaust sounds more like a poooof poooof. If you have any ideas let me know. Ive cleaned the carb, and checked for a vacume leak, but could have easily missed something. Thanks Stinson
Re: 22r running rough at idle [Re: Stinson] #488179 08/13/04 01:48 AM
kewlynx Offline
How dirty was your carb? You might have your EGR getting a bit plugged if it was carboned up pretty good. Also when's the last time you gave 'er a good tuneup? Might be all you need to do.
**ubi apis- ibi salus**
Re: 22r running rough at idle [Re: kewlynx] #488180 08/13/04 02:30 AM
i would check the aap.
sounds like its that
davef
Re: 22r running rough at idle #488181 08/13/04 02:48 AM
randito Offline
What exactly are the symptoms of a bad aap? I have very different problems with my '85 22r and it was suggested that I replace the aap.
1985 runner, completely stock(still)
Re: 22r running rough at idle [Re: randito] #488182 08/13/04 03:07 AM
the symptoms of the aap is very rough at cold idle....it will likely clear a bit after the engine warms up. most likely if it is leaking the carb will be very dirty (vacuum lines deteriorating from gas) and the engine will run very rich. alot of black smoke from exhaust. a simple test to check if aap is leaking is apply vacuum ( i did this with my mouth but if you don't like the taste of gasoline do not do it this way) when you apply vacuum ....if the diaphram is not leaking .....no gas will come from the vacuum hose. when you release vacuum a small amount of gas will shoot into the carb from the jet.
good luck
davef
Re: 22r running rough at idle [Re: randito] #488183 08/13/04 05:35 AM
ArbitraryNotion Offline
Bad AAP is kinda a cure-all. There are so many drivability problems that are associated with that diaphram going bad. I've seen very mild idle problems to engines cutting out on the highway. It depends on how big the hole is. A couple very easy checks are:
Remove the vac line connected to it. If it looks/smells of gas, the diaphram is bad. Also, the no1 spark plug will look black and sotty, more so than the others.
Personally, when the AAP goes bad, its better to rebuild the whole carb and change out all the gaskets and the other 2 diaphrams. Plus the neddle seat and readjusting the float... If I only still had somewhere to rebuild carbs...
Josh
1986 Toyota 4x4 22wEBer
Ported EB Offroad H/O Head "Josh Cam"
Ported Intake & Weber38mm Carb
LCE Header & 2.25in Exhaust
RB 1" BL, RS5000, SAW Tbars
2011 FJ Cruiser - SOLD
Re: 22r running rough at idle [Re: ArbitraryNotion] #488184 08/13/04 05:42 AM
can somebody please tell me what AAP stands for?
That's not an abbreviation we 'Zu guys use, but it sounds like you're describing an EGR backpressure transducer, or Toyota's equivalent.
Sorry for invading your board, but the title caught my eye as I have been battling a rough idle for some time on my Trooper.
Thanks,
Phil
Re: 22r running rough at idle #488185 08/13/04 05:53 AM
AAP = Aux Accel Pump (sorry I can't spell...)
auxilery Accelerator pump...
auxillery Accellerator pump...
Eh you know what I mean...
Josh
Re: 22r running rough at idle [Re: Stinson] #488186 08/13/04 09:53 PM
VAHunter17 Offline
Maybe it grew a EB camshaft overnight...wouldn't it be nice!
'98 Tacoma TRD ext.cab 2.7 5spd 6inFabtech sus w/ 33x12.5.15 TrxusSTS on 15x10 DC-1 (Black)
'90 4Runner 3.0auto stock as of now
Re: 22r running rough at idle [Re: VAHunter17] #488187 08/13/04 11:35 PM
engnbldr Offline
>>>*I heard that...*LOL** Them *EB cams runs smoother than a new born babie's behind with Apple Butter onnit....
(...*welll...kinda...)
Say I talked to a guy in GA today, he had a sputter that sounded like a missfire, hesitation then fine with a dab of throttle. Injector hanging up at slow speed was all that was.......*EB
*Beats the he** outa me!....*LOL**...
PHP: 7.4.33 Page Time: 0.011s Queries: 15 (0.008s) Memory: 0.6295 MB (Peak: 0.7319 MB) Data Comp: Off Server Time: 2026-11-16 01:16:05 UTC
