Rear window not working on 98' Runner #489439 08/15/04 06:00 PM
Hugh Offline OP
Twenty questions...
Is the rear window on a 98' supposed to operate with the key? I know this works with 1st and 2nd generations, but mine has never worked with the key.
Are all the windows on the same fuse? side and rear windows all on one curcuit? Which fuse operates the rear?
How do I check the rear window switch?
Thanks in advance <img src="/forums/images/graemlins/cheers.gif" alt="" />
Hugh
94' 4Runner SR5 3.0L, 4X4, 5-speed, 200K
01' Sienna XLE, 105K, auto everything...
91' Ford F-250, 7.3 liter IDI diesel, 5-speed, 170K
Re: Rear window not working on 98' Runner [Re: Hugh] #489440 08/15/04 09:48 PM
E
ed_herman Offline
The rear window should work via the key. There is maybe a five second delay.
Re: Rear window not working on 98' Runner [Re: ed_herman] #489441 08/17/04 11:15 PM
Hugh Offline OP
After the overwhelming response... <img src="/forums/images/graemlins/sleeping.gif" alt="" />
The key doesn't make it work either and hasn't since I've owned it. My plan is to remove the rear door cover with my special door panel tool and see if the ground wire is disconnected or not.
Hugh
Re: Rear window not working on 98' Runner [Re: Hugh] #489442 08/18/04 02:57 AM
FattyCBR Offline
I have no idea about the fuse the rear window is on, check the owner's manual though, they have a trouble shooting guide. Also does the rear window go down using the switch in the center console? If so you can isolate the problem to the keyed switch in the rear hatch.
Milan
_ _ _ _ _ _ __ _ _ _ _ _ _
Support our troops!
'98 4R Limited
'82 Toy 4.3 TBI sold
Re: Rear window not working on 98' Runner [Re: FattyCBR] #489443 08/18/04 01:16 PM
Hugh Offline OP
No, window has never worked via key and it used to work with inside switch. I've owned this Runner since last Dec. Both circuits are toast at the moment, all other windows work fine.
Hugh
Re: Rear window not working on 98' Runner [Re: Hugh] #489444 08/18/04 01:29 PM
I had the same problem over the winter where my rear window wouldn't respond via the center console switch. It would however roll down using the remote. I've never tried rolling it down via the key....I'll give it a try tonight and get back to you.
Re: Rear window not working on 98' Runner #489445 08/18/04 11:16 PM
G
Germ Offline
4crawler has an excellent write up on how to diagnose the problem here: 4Crawler
Start with the basics...fuses, lock switch, etc. Mine was a bad ground (85 4runner).
Good luck
Erik <img src="/forums/images/graemlins/cheers.gif" alt="" />
Twenty years from now you will be more disappointed by the things you didn't do than by the ones you did.
85 4Runner, New motor, Dual cases, 4.88's, ARB's (F/R), 4" lift, 33's, Warn M8000#.
Re: Rear window not working on 98' Runner [Re: Germ] #489446 08/23/04 11:22 PM
Hugh Offline OP
I'll check out the link.
Yesterday, I checked all fuses, remote switch and power to the switch...all good. I also pulled off the rear door panel, lots to look at, but I don't know where to start. The repair manual that I have doesn't show anything about the rear window workings.
Any suggestions? <img src="/forums/images/graemlins/patriot.gif" alt="" />
Hugh
Re: Rear window not working on 98' Runner [Re: Hugh] #489447 08/24/04 02:12 AM
Pappy Offline
Twenty questions...
Hugh
Uh, I hate to ask something stupid ... but with the lift gate on the Gen3 4Runners I thought the rear window was fixed and didn't roll up or down. That was a feature for those of us for tailgates. Am I wrong here?
Re: Rear window not working on 98' Runner [Re: Pappy] #489448 08/24/04 11:24 AM
FattyCBR Offline
Twenty questions...
Hugh
The rear glass does go into the gate.
Milan
Support our troops!
'98 4R Limited
PHP: 7.4.33 Page Time: 0.012s Queries: 16 (0.009s) Memory: 0.6370 MB (Peak: 0.7597 MB) Data Comp: Off Server Time: 2026-11-01 22:31:21 UTC
