Air condition is not working on '02 Tacoma? #490822 08/18/04 10:15 PM
TCAO Offline OP
Hey Guy,
I plan to bring my Tacoma to the dealer to have the A/C checks out, because it is still under warranty, but I fear those certified mechanics would mess up my truck. Can anyone help me spot out the solution? My A/C is not cold at all, only the fan is working.
Re: Air condition is not working on '02 Tacoma? [Re: TCAO] #490823 08/19/04 02:26 AM
is there any freon in it? may just need a recharge, but in that case you might have a leak somewhere because it doesn't just disappear <img src="/forums/images/graemlins/shocked.gif" alt="" />
Re: Air condition is not working on '02 Tacoma? [Re: TCAO] #490824 08/19/04 01:48 PM
Things to check:
1) Is there any refrigerant (pressure gague)
2) Is the compressor turning on. Watch the compressor hub when the A/C is turned on, it will spin when you first turn it on.
3) If there is refrigerant and the compressor is running, then is there ENOUGH refrigerant. You can watch the eye on the dryer (little megal canister near the front with the peep hole). If you see a pile of bubbles then that's a sign that you might be low. A set of pressure gagues would also be required, you need to check the pressure on the high and low side of the compressor while the A/C is running and see if they are within spec.
Assuming your problem is as simple as being low on refrigerant then you have a leak and you haev to find it. You can find it with a sniffer (expensive, find someone who has one). You can also find it by putting die into the A/C system, then crawling around under the hood with a blacklight. The dye will glow where it is leaking.
Be aware that any leak that is caused by something other than a loose fitting will likely require the A/C shop to empty the system and take that part off to fix/replace it. Before it is refilled with refrigerant it will have to be evacuated (pumped under vacuume for a period of time) to remove any air/moisture.
There you go, that's all I know about A/C, hope this helps. It coule be something simple like a bad compressor clutch, or it could be something bad like a dead compressor. Shouldn't be that hard to diagnose, A/C isn't very complicated.
Re: Air condition is not working on '02 Tacoma? #490825 08/20/04 06:41 AM
Stock02 Offline
That's one thing I'd let the dealer tackle under warranty.
02 Tacoma Xcb 4x4, runnin 32"s, 2.5" Daystar spacers, 1.5" Downey HD shackles, AOR sliders, SkidRow Tcase skid, 20# CO2 setup
PHP: 7.4.33 Page Time: 0.005s Queries: 15 (0.003s) Memory: 0.5951 MB (Peak: 0.6543 MB) Data Comp: Off Server Time: 2026-05-25 18:57:40 UTC
