yota drive shaft to a dana 44?'s #492689 08/23/04 05:36 AM
94rodeo Offline OP
is there an adapter that allows one to run a stock yota drive shaft to a dana 44?
94 Rodeo
sas'd front dana 44(coil sprung), dual transfer cases (isuzu), tera lows, custom bumpers, winch, arb lockers[url= [url=http://community.webshots.com/user/94rodeo] [url=http://community.webshots.com/user/94rodeo[/url]http://community.webshots.com/user/94rodeo[/url]
Re: yota drive shaft to a dana 44?'s [Re: 94rodeo] #492690 08/23/04 07:42 AM
kyle-22r Offline
yup, high angle driveline makes a pinion flange that replaces the yoke on a dana 44
'91 4x4 shortbed
22R-E, W56, the dd!
Re: yota drive shaft to a dana 44?'s [Re: kyle-22r] #492691 08/24/04 03:21 AM
94rodeo Offline OP
any idea how much one costs?
94 Rodeo
Re: yota drive shaft to a dana 44?'s [Re: 94rodeo] #492692 08/24/04 03:44 AM
OOP'S Offline
Call Jess or e-mail him!!!!! http://www.highangledriveline.com/
David Fritzsche
Roseville, CA
"Serenity through Sobriety"
Re: yota drive shaft to a dana 44?'s [Re: OOP'S] #492693 08/25/04 04:14 AM
94rodeo Offline OP
just so you know they run around $99
94 Rodeo
Re: yota drive shaft to a dana 44?'s [Re: 94rodeo] #492694 08/25/04 02:19 PM
DRM Offline
I run the Dana 60 flanges so I could keep my Toyota driveshafts and I flat out love them. Hard to swallow the initial price, but you get to keep superior U joints that are stronger and capable of more angularity.
Re: yota drive shaft to a dana 44?'s [Re: 94rodeo] #492695 08/25/04 06:25 PM
Wow, if that's the case then the price has dropped substantially in the last 2 years. I seem to recall the 44 to Toy flange adapter being something like $160 when I called Jess about it back then. At that point I just elected to get a hybrid shaft from him with a 44 joint on one end and the toyota CV on the other. At $99 I would definitely go with the all toyota driveshaft and adapter flange.
Re: yota drive shaft to a dana 44?'s #492696 08/25/04 06:40 PM
DRM Offline
Yes, the prices have dropped considerably, and just recently.
Re: yota drive shaft to a dana 44?'s [Re: DRM] #492697 08/27/04 03:02 PM
I've been running one of Jess's Dana44/Toy flanges in my HO 4Runner for over a year but I can't recall what it cost back then. An excellent product which makes it easy to swap a Toy axle back in if ever needed.
Re: yota drive shaft to a dana 44?'s [Re: 94rodeo] #492698 08/30/04 09:43 PM
houlster Offline
Isuzu Moderator
Two more choices to think about:
1.
Swap the D44 yoke with an Isuzu D44 pinion flange (about $45 new from St. Charles) and an Isuzu driveshaft flange (you've probaly already got one from your original driveline). You need a flange for an Isuzu u-joint (inside snaprings), not a 1310 u-joint (outside snaprings). Isuzu used both. The Isuzu driveshaft flange will fit the Toy u-joints and bolt right up the the D44 pinion flange.
Pic: This one went on my Dana 300, which has the same splines as the D44 pinion:
Use a 1310 / Toy conversion u-joint from Rockford driveline. Take off the flange and u-joint from the Toy driveshaft and use this one to connect it to a 1310 D44 yoke (assuming the D44 has 1310 yokes of course).
--Dan
PHP: 7.4.33 Page Time: 0.009s Queries: 15 (0.006s) Memory: 0.6286 MB (Peak: 0.7351 MB) Data Comp: Off Server Time: 2026-11-01 20:21:45 UTC
