IFS bump stop question.. #43742 11/26/02 08:41 PM
RAZZMATAZ Offline OP
What would happen if I lowered my UCA bump stop mounts?? Or should I just cut off the mounts all together?
I removed the rubber bump stop a few years ago, but I am getting tired of the popping sound every time the suspension "tops out".
Anyone ever tried this??
Cheers
RAZZ
87 4Runner 22R-TE
4 Pro Comp IFS
63 Chevy springs
5.71 gears
Detroit in rear, Lockright in front
35 MT/R
Rancho 9000
Jacobs ProStreet ign module and Ultra coil
1992 3VZ-E swapped in
Re: IFS bump stop question.. #43743 11/27/02 01:00 AM
Rodgertheshrubber Offline
have you had problems with your ball joints since removing the UCA rubbers? did you remove the lowers too?
"I am a shrubber, my name is Rodger the Shrubber. I arrange, design, and sell shrubberies"
Re: IFS bump stop question.. #43744 11/27/02 01:40 AM
Brian894X4 Offline
</font><blockquote><font size="1" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">quote:</font><hr /><font size="2" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">Originally posted by RAZZMATAZ:
<strong>What would happen if I lowered my UCA bump stop mounts?? Or should I just cut off the mounts all together?
Cheers
RAZZ</strong></font><hr /></blockquote><font size="2" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">One thing that would concern me is the limitations of the inner joint. The outer birfield can withstand greater than stock angles and regularly does with the longer than stock A-arm kits, but the inner joint is limited in it's "in and out" movement and may pull itself out of the socket when fully extended without the bumpstop or bumpstop relocated. Not that I would go pushing the outer joint too much. It too could break when you least expected it.
The 2 or 3 inches of extra travel is probably not worth the risk of breaking something on the trail. Have you considered going with one of the longer than stock A-arm kits. They are a bit spendy, but well worth it, if an SAS is not your future. You can get a ton more travel than you ever could with the stock A-arms.
Re: IFS bump stop question.. #43745 11/27/02 02:09 AM
Just put on some "Ultra Low Profile Bump Stops".
Re: IFS bump stop question.. #43746 11/27/02 05:57 AM
i'm gonna cut mine in half
they squish considerably at stock height
that's why i wouldn't cut more off
those low profile ones don't look thick enuf to me
and i prefer rubber
so, you had no probs with no stop at all?
i've had some with no lower bumpstops <img border="0" alt="[Nerd]" title="" src="graemlins/nerd.gif" />
not a good idea... <img border="0" alt="[Rat]" title="" src="graemlins/rodent.gif" />
i also put some divets in the frame clamping 3/4 springs to it with 'u bolts' <img border="0" title="" alt="[Frown]" src="images/icons/frown.gif" />
Re: IFS bump stop question.. #43747 11/27/02 07:49 AM
code33 Offline
It's been used time and time again by many w/o any problems.
But it's your truck and you can do as you choose.
</font><blockquote><font size="1" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">quote:</font><hr /><font size="2" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">Originally posted by toynado:
<strong>
<small>[ November 27, 2002, 01:49 AM: Message edited by: code33 ]</small>
Classifieds & Suzuki Moderator
Re: IFS bump stop question.. #43748 11/27/02 08:14 AM
I have removed both upper and lower bump stops.. no problems yet!! I also forgot to mention that I have a procomp 4" lift, Will the after market arms work with this lift??
I've been putting off a SAS.. I like the way my truck rides now + I pull a boat about 150 miles( oneway) every other weekend in the summer.
Later,
RAZZ
87 4Runner 22R-TE
4 Pro Comp IFS
63 Chevy springs
5.71 gears
35 MT/R
Rancho 9000
Re: IFS bump stop question.. #43749 11/27/02 05:07 PM
elripster Offline
<strong>I have removed both upper and lower bump stops.. no problems yet!! I also forgot to mention that I have a procomp 4" lift, Will the after market arms work with this lift??
Later,
RAZZ</strong></font><hr /></blockquote><font size="2" face="Verdana, Tahoma, Arial, Helv, Helvetica, Sans">If you are concerned about angle, just pull out a half shaft and see how far it can go before it runs out of angle.
With increasing droop you are unlikely to see problems because when the suspension is at full droop, there is little force on the wheel if at all. Often the suspension is at full droop because the wheel isn't even on the ground. What angle your a-arms end up when all the weight is on a wheel will make a much bigger difference in CV failure.
Frank
1994 4runner, 3.0, auto, 4.88's, 31's, BJ spacers, Coil spacers, air shocks, D-ring anchors, 4Crawler F/R swaybar discos.
www.sdori.com
PHP: 7.4.33 Page Time: 0.013s Queries: 14 (0.009s) Memory: 0.6204 MB (Peak: 0.7185 MB) Data Comp: Off Server Time: 2026-11-17 11:26:16 UTC
