Page 4 of 4 1 2 3 4
Re: Warn Hubs$$ [Re: wd8cdh] #494970 09/11/04 11:03 AM
Axe Man Offline
Kia Moderator Emeritus
I don't think that the turning will make that much differance in CV boot life. After all, FWD vehicles are always turning the boots and they usually only fail due to dryrot or tearing.
That's true. But make sure that the slip joint on the front driveshaft is well greased if you are going to drive around with the hubs locked. I didn't and paid the price. The slip joint froze up so the front driveshaft couldn't flex under torque. That put stress on the front diff pinion seal and it blew. Needed new pinion seal AND new front driveshaft because it was rusted solid. Ask Dave, I sent him my old driveshaft. <img src="/forums/images/graemlins/shocked.gif" alt="" />
1998 Sportage - Gone.
2004 Honda Civic Coupe.
2007 Suzuki Grand Vitara - She got it.
Re: Warn Hubs$$ [Re: fishman] #494971 09/12/04 06:38 PM
Lou Offline
Lou,
Can anyone post a picture of what the replaced hub & wheel looks like.
thanks,
Hamk
Here is what I've done for the mechanical autolockers. The KIA logo is part of the hub, not glued.
Re: Warn Hubs$$ [Re: fishman] #494972 09/17/04 08:56 PM
FYI.. for anyone looking for the hubs. I just took delivery of the automechanical ones #61918. The order took about three days to get. I ordered from:
Performance Parts
The manual #60247 are there for $117 and the auto #61918 are there for $138. The price was a little higher for the manuals than I have seen elsewhere, but the delivery was quick.
I have one question for the more experienced folks here. Do I need a spindle nut wrench to install the hubs? The instructions mention a small torque (3.5-7 lb-in) for the spindle nut. If not, what did you use to torque it down?
Thanks,
Chris
Re: Warn Hubs$$ #494973 09/20/04 12:50 PM
brntrt Offline OP
Thanks for the link Chris that's the best price I've seen. <img src="/forums/images/graemlins/patriot.gif" alt="" />
Mark Brown
2002 Sportage 2 Door
Eibach lift,Coil Spring spacers, Body lift, K&N, 9.50x30 M/T
Re: Warn Hubs$$ [Re: brntrt] #494974 09/20/04 06:08 PM
F
fishman Offline
I am assuming that the Warn AutoLocker hubs still work off of the vacuum as the original stock KIA hubs?
Sportage, 1998, 4X4, 5 spd, Factory Config., vacuum hubs, 4 door, 100K miles
Weekender-1975 Bricklin, 351CI, auto, Gull Wing, 13K miles
Re: Warn Hubs$$ [Re: fishman] #494975 09/20/04 06:16 PM
Axe Man Offline
No, they are totally mechanical and the vacuum system is not needed.
Re: Warn Hubs$$ [Re: Axe Man] #494976 09/20/04 08:49 PM
F
fishman Offline
I am confused? As I understand it, the manual hubs you have to get out of the car and by hand lock each hub. How does the Warn AutoLocker hub engage if it is not using the vacuum system or the hubs are not locked individually by hand?
Re: Warn Hubs$$ [Re: fishman] #494977 09/20/04 10:06 PM
Lou Offline
They are "mechanically" activated by the very rotation of the driving shaft. If shaft does not rotate, hubs do not engage. If shaft rotates, hub engages. The exact way this happens is a little difficult to describe in a few words, but I'll post something about that some day.
Page 4 of 4 1 2 3 4
PHP: 7.4.33 Page Time: 0.007s Queries: 16 (0.004s) Memory: 0.6300 MB (Peak: 0.7249 MB) Data Comp: Off Server Time: 2026-05-25 18:18:33 UTC
